Differentiate enabled vs disabled parts in Assembly using VBA
I have an assembly where I count parts and place them in a database.
Currently, I am counting all parts (by name). I would like to exclude the
parts where the snabled feature is turned off in the specific assembly.
For Each oPCompRef In oPCompRefs
PartNo = Left((oPCompRef.ReferencedFileDescriptor.DisplayName),
Len(oPCompRef.ReferencedFileDescriptor.DisplayName) - 4)
QTY = oPCompRef.ImmediateOccurrences.Count
I am thinking possibly, that changing the QTY variable to ount differently
might be a viable solution. On the other hand, perhaps there is another if
agrument that must be added???
Thanks in advance for your help!
Steve Anderson
Engineer / Documentation Coordinator _
METRO MACHINE & ENGINEERING CORP.
vmail: (952) 259-3683 fax: (952) 937-2374
email: sanders.tec@netzero.com
-- NOTE NEW EMAIL ADDRESS --
If I understand correctly it should just be something like this
if oPCompRef.Enabled = True then
end if
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Stephen Anderson" wrote in message
news:45822FE41694A75528C8C449DDCA30DE@in.WebX.maYIadrTaRb...
> Steve Anderson
Kent is close, but there's a slight change that's needed. Try this:
Public Sub CountEnabled()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oCompRef As ComponentDefinitionReference
For Each oCompRef In
oDoc.ComponentDefinition.ImmediateReferencedDefinitions
Dim iQty As Long
iQty = 0
Dim oOcc As ComponentOccurrence
For Each oOcc In oCompRef.ImmediateOccurrences
If oOcc.Enabled Then
iQty = iQty + 1
Next
Dim strPartNo As String
strPartNo = Left((oCompRef.ReferencedFileDescriptor.DisplayName),
Len(oCompRef.ReferencedFileDescriptor.DisplayName) - 4)
Debug.Print strPartNo & ", Qty: " & iQty
Next
End Sub
Brian Ekins
Developer Technical Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
"Kent Keller" wrote in message
news:BDB8F35A0F117F4202EBE876A5D12228@in.WebX.maYIadrTaRb...
> end if
> Kent
> Assistant Moderator
the
differently
if
> > Steve Anderson
oPCompRef.Enabled - produces a runtime error 438 - Object doesn't support
property or method.
My quesion is, what if there are three identical parts and only two are
enabled? Can the count work differently? If not, I can deal with it, but
what exactly is missing from your if statement below?
Thanks for your response!
> end if
> Kent
> Assistant Moderator
the
differently
if
> > Steve Anderson
What version are you on? In R6 and earlier help there was a really nice little example of
iterating through subs and counting. I don't have it here, and don't have time to
recreate it, but I could post a copy tonight if no one else does.
It has two subs, one that does all the top level components, and the second one iterates
through all the subs components. In this second one you should be able to skip the
count simply by checking if the component is enabled or not and using that to decide if
you wanted it added to the count or not.
Kent
Assistant Moderator
news:DBBB12277B7E0E3C20925B8AC081BD5F@in.WebX.maYIadrTaRb...
> property or method.
Actually Kent go ahead and post it. I'm going to need something close to it
in a few week for a work project.
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
news:9756EE21134BE540FEEA905780A9AC03@in.WebX.maYIadrTaRb...
little example of
have time to
second one iterates
to skip the
to decide if
> Kent
> Assistant Moderator
support
> > property or method.
but
Neither of these work, nor your example of oPCompRef.Enabled. Any other
ideas?
oPCompRef.ReferencedDefinition.Occurrences.Item.Enabled
oPCompRef.ImmediateOccurrences.Item.Enabled
Thanks for your help on this!
> end if
> Kent
> Assistant Moderator
the
differently
if
> > Steve Anderson
