Determine which feature was created by using a specific SketchBlock
MD_
Message 1 of 1
MD_
Similar to this post: Determine which feature was created by using a specific sketch, API - Autodesk Community
Is this possible for sketchblocks?  Can the feature(s) using a sketchblock be found in a similar way using the dependents property?  I tried the following but keep getting an error:
Dim oPartDoc As PartDocument = ThisDoc.Document
Dim oPartCompDef As PartComponentDefinition = oPartDoc.ComponentDefinition
Dim oSketchBlockDef As SketchBlockDefinition
For Each oSketchBlockDef In oPartCompDef.SketchBlockDefinitions
	For Each oDependent In oSketchBlockDef.Dependents
		'  ... Error "Object reference not set to an instance of an object."
	Next
Next
Replies (0)
