Determine if occurrence is a design accelerator component
Is there any way to know if an assembly occurrence is a design accelerator component (ie bolted connection, shaft, etc). I have an assembly and I am looping through all the components for further processing and I need to handle design accelerator assemblies in a different manner from assemblies.
Nate
HermJan.Otterman
look at the attributes of the occurences, there is some info
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Herm Jan, Thanks for the reply but unfortunately the reason I posted is because I am not having any luck looking through the attributes. Do you know which attribute will indicate what I am looking for? I've searched the attributes, looked through the documentation and tried googling but I haven't found the needle in the hay stack.
Nate
