Determine How iLogic is Being Called
Matthew_Policelli
Matthew_Policelli
Is there a way to determine if an iLogic rule is being called through a form or through an event trigger, and prompt the user for confirmation ONLY when it is being called by an event trigger?
The rule in question creates a PDF. If the user is pressing a button on a form to run the rule, I'd like it to just create the PDF no questions asked. However, if the rule is running because of an event trigger, I would like it to ask the user if they want to create the PDF or not.
Curtis_Waguespack
Hi @Matthew_Policelli
You will need 2 rules.
Let's call them :
  1. PDF Button Rule
  2. PDF Rule
On the form, use the rule called "PDF Button Rule" as the button.
The event trigger still calls the original rule (  "PDF Rule" in this example )
The code for "PDF Button Rule" will call the "PDF Rule" and send it an argument to tell it to ask questions or not ask questions, and would be something like this:
Dim oValueMap As Inventor.NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap()
oValueMap.Add("SkipPrompt", True)
iLogicVb.RunRule("PDF Rule", oValueMap)
The PDF Rule would have some code at the beginning to receive the argument from the other rule, and use it to determine if it needs to prompt the user. It would look something like this:
'set default value for variable
oSkipPrompt = False
'try to set variable based on argument from other rule
oSkipPrompt = RuleArguments("SkipPrompt")
If oSkipPrompt = False Then
	oInput = MessageBox.Show("Are you sure you want to create the PDF?", "iLogic",MessageBoxButtons.YesNo)
	If oInput = vbNo Then Exit Sub
''' code to create PDF here
''' code to create PDF here...
 MessageBox.Show("your PDF was created!", "iLogic")
I hope this helps.
Curtis
Matthew_Policelli
I'm accepting this as an answer. Also, this led me down the rabbit hole of learning about RuleArguments and SharedVariables, which I previously didn't know were a thing!
One last question I have is this: Your answer used RuleArguments, but would creating a SharedVariable, running the rule, and then deleting the SharedVariable work just as well? Is there a reason to use one over the other?
Curtis_Waguespack
I think ShareVariables are useful when we want to create/set a variable in Rule 1 and have Rule 2, 3, 4 and 5 use that value, and maybe even update that value along the way.
The form & event trigger scenario is a bit more simple, but indeed you could use a ShareVariable for that scenario as well.
I tend to use rule arguments when I am handing a value to a rule, as a single action. If I want that value to persist in memory, so that another rule "might" use, I use a shared variable. That is just my thought on it though, I don't think there are any strict rules as to when to use on or the other.
