Detecting "No Effect?" Sheet Metal cuts and extrusions
How can I detect sheet metal cut and extrusion cut features that have the white circular model browser node icon wih the "i" insided it (toolip says "No effect?") via the Inventor API? You get this situation if the sketch does not cut any geometry. I want to delete these features.
Any Ideas?
I'm using Inventor 2012 and VB.Net.
Thanks!
I found a way to do this...
    Private Sub RemoveStrandedCutFeatures()
        Dim oPartDoc As PartDocument
        oPartDoc = _invApp.ActiveDocument
        If oPartDoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
            Exit Sub
        Dim oPartDef As PartComponentDefinition = oPartDoc.ComponentDefinition
        Dim oSheetMetalFeatures As SheetMetalFeatures
        oSheetMetalFeatures = oPartDef.Features
        Dim oCutFeatures As CutFeatures
        oCutFeatures = oSheetMetalFeatures.CutFeatures
        For Each Cut As CutFeature In oCutFeatures
            If Cut.HealthStatus <> HealthStatusEnum.kUpToDateHealth Then
                Cut.Delete()
        Next
    End Sub
