Description as a Sheet Name
kresh.bell
kresh.bell
is it possible to make iLogic that will assign the Description Standard iPropertie from Primary or attached model to the Sheet name. If there is no such property then skip it.
WCrihfield
I don't think so, at least not 'linked' like that.  It could be a 'static' value though.  We never see the Format Text dialog when editing the sheet, no matter if we do it directly through the model browser tree, or within the Edit Sheet dialog.  And there is no FormattedText aspect to the Sheet.Name property to insert the required XML tags for the formatting.
There is also this:
Wesley Crihfield
(Not an Autodesk Employee)
