Deriving Solids from Multi-Solid Body iPart
Message 1 of 24
Hello all,
I would like to write an iLogic rule that does the following for a currently open part that has multiple solid bodies:
1.  Derive each solid body as its own part
2.  Save derived part with one of three suffixes in the same folder as original part
3.  (Ideal, but optional) Place derived part in a new assembly with same name as original part
4.  Repeat for all solid bodies in original part
So why do I not just use the 'Make Components' function?  The parts that I need this rule to run on (there are hundreds) are all iParts, and the Make Components function is not available for iParts with multiple solid bodies.
Any help would be appreciated.  I have done very minimal coding in the past, but my usual method of Frankensteining code together from posted examples has failed me.  Thanks in advance.
Replies (23)
Message 21 of 24
Thank you so much!  This worked exactly how I wanted it to.  I just had to add a few lines to name the parts how I needed them and save the resulting assembly how I wanted it.  I also needed to set the display name to be the same as the file name for the parts.  Thank you!
A quick question though, whenever I tried to run your code, I would get an error message that would say something like "Let and Set are not supported anymore."  I had to remove the word Set from any lines that contained it and then it ran perfectly.  Why is this?  Anyways, thank you so much you've saved me hours of busy work.
Here is my final code, for anyone interested:
Sub Main()
    ' set a reference to the active partdocument
    Dim prt As PartDocument
    'Set prt = ThisApplication.ActiveDocument
    Dim template As String
    Dim folder As String
    template = "F:\Drafting & Design\The Box\Inventor\Templates\Standard.ipt"
    folder = PathName(prt.fullFileName)
	Dim parname As String
	parname = ThisDoc.FileName(False) 'without extension
    ' create an object collection to store the parts to put in assembly
    Dim prtCol As ObjectCollection
    prtCol = ThisApplication.TransientObjects.CreateObjectCollection
    Dim a As Integer: a = 0
	Dim suffix As String
    ' loop through the filtered selection
    Dim sb As SurfaceBody
    For Each sb In prt.ComponentDefinition.SurfaceBodies
        ' create a new part to derive the solid body in
        Dim newPart As PartDocument
        newPart = ThisApplication.Documents.Add(kPartDocumentObject, template, True)
        ' set a reference to the derivedpartcomponents
        Dim dpcs As DerivedPartComponents
        dpcs = newPart.ComponentDefinition.ReferenceComponents.DerivedPartComponents
        ' create the scale definition
        Dim dpd As DerivedPartUniformScaleDef
        dpd = dpcs.CreateUniformScaleDef(prt.fullFileName)
        ' set the settings in another sub
        Call settingsDerivedPart(dpd, sb)
        Call dpcs.Add(dpd)
        Call prtCol.Add(newPart)
        ' set the part title to the solidbodies name
        newPart.PropertySets.Item("Inventor Summary Information").Item("Title").Value = sb.Name 'sb.CreatedByFeature.Name
        a = a + 1
		If a = 1
		suffix = "WEB"
		If a = 2
		suffix = "TF"
		If a = 3
		suffix = "BF"
		' Save the part
        ThisApplication.SilentOperation = True
        Call newPart.SaveAs(folder & parname & " " & suffix & ".ipt", False)
		newpart.DisplayName = parname & " " & suffix
		ThisApplication.SilentOperation = False
    Next sb
    'Create a new assembly to put parts in
    Dim asm As AssemblyDocument
    asm = ThisApplication.Documents.Add(kAssemblyDocumentObject)
    ' place in assembly
	prt = Nothing
    For Each prt In prtCol
        ' create an empty matrix
        Dim mx As Matrix
        'Set mx = ThisApplication.TransientGeometry.CreateMatrix()
        Dim occ As ComponentOccurrence
        occ = asm.ComponentDefinition.Occurrences.AddByComponentDefinition(prt.ComponentDefinition, mx)
		Call prt.Close(True)
    Next
	'Save assembly in same folder and with same name as parent file
	Call asm.SaveAs(folder & parname & ".iam", False)
End Sub
Function PathName(FullPath As String) As String
 ' return all left of last \
 PathName = Left(FullPath, InStrRev(FullPath, "\"))
End Function
Sub settingsDerivedPart(ByRef dpd As DerivedPartUniformScaleDef, sb As SurfaceBody)
    ' set the derive style
    'dpd.DeriveStyle = kDeriveAsSingleBodyNoSeams
    'dpd.UseColorOverridesFromSource = False
    Call dpd.ExcludeAll
    ' include solid, exclude the others
    Dim dpe As DerivedPartEntity
    For Each dpe In dpd.Solids
        If dpe.ReferencedEntity.Name = sb.Name Then
            dpe.IncludeEntity = True
    Next
End Sub
Message 22 of 24
basnederveen
No problem!
Hmm.. Are you using an iLogic rule or did you make a macro
Message 23 of 24
I made this into an external rule. Would it be better to use it as a macro? I don't really know how to do that.
Message 24 of 24
Andrew_Burnett
I tried your code and it works great.  I have a piece of pipe that we cope and cut.  The shop needs a paper wrap pattern to lay this out.  What I did is have completed coped piece of pipe and then created a separate body in the part that is a thickness of paper.  I am looking to make the component from this but need to have it in our sheet metal template.  Is there a specific way to do this?
Thank you
