Deriving multi-body-part files into merged solid part files
Daan_M
Daan_M
I have a folder with around 100 .ipt files, each file consisting of multiple solid bodies.
I would like iLogic to make a copy of each of these files in a new folder, where it merges the solid bodies of the original file into one solid.
I figured using the 'Derive' functionality would be suitable for this, but i can't fully figure out the code.
' Define source and destination folders
Dim sourceFolder As String = "D:\Source\"
Dim targetFolder As String = "D:\Target\"
' Get the list of .ipt files in the source folder
Dim filePaths() As String = System.IO.Directory.GetFiles(sourceFolder, "*.ipt")
' Loop through each file
For Each filePath As String In filePaths
    ' Create a new part document
    Dim newPartDoc As PartDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kPartDocumentObject,, True)
    Dim newCompDef As PartComponentDefinition = newPartDoc.ComponentDefinition
    ' Create Derived part definition
    Dim derivedPartDef As DerivedPartUniformScaleDef
    derivedPartDef = newCompDef.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(filePath)
    ' Define Derive style
    derivedPartDef.DeriveStyle = DerivedComponentStyleEnum.kDeriveAsSingleBodyNoSeams
    ' Add the derived part to the new part
    newCompDef.ReferenceComponents.DerivedPartComponents.Add(derivedPartDef)
    ' New file save location
    Dim fileNameOnly As String = System.IO.Path.GetFileName(filePath)
    Dim newFilePath As String = System.IO.Path.Combine(targetFolder, fileNameOnly)
    newPartDoc.SaveAs(newFilePath, False)
    ' Close new part
    newPartDoc.Close(True)
Next
So far it does create the new file in the target folder and i do see a reference to the original file in my modeltree (FMS_056...), but i don't see a physical 3D model:
(The model/derive link can be deleted in the final code)
Andrii_Humeniuk
Hi @Daan_M .
Your code works fine for the test parts I created. Perhaps in your case the body combination is not successful due to the complex geometry of the part.
Can you provide a sample for testing?
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Daan_M
Hi @Andrii_Humeniuk,  thanks for the reply.
I've attached a sample file for testing.
Andrii_Humeniuk
Hi @Daan_M . Thanks for the example, it made it easier to understand what is missing.
In your case, including all solids using the IncludeAllSolids property is missing.
If filePaths.Count = 0 Then Exit Sub
If Not IO.Directory.Exists(targetFolder) Then IO.Directory.CreateDirectory(targetFolder)
Dim oDocs As Documents = ThisApplication.Documents
    Dim newPartDoc As PartDocument = oDocs.Add(DocumentTypeEnum.kPartDocumentObject,, False)
	derivedPartDef.IncludeAllSolids = DerivedComponentOptionEnum.kDerivedIncludeAll
    ' Close new part
Next
