Depth markers on drawing
NachoShaw
Advisor Advisor
NachoShaw
Hi
 Getting ready to start a new code task for my cnc tool and thought I'd reach out here for some pointers.
My cnc tool loops an assembly for all parts, places then largest face down in landscape with a detailed label in groups of material. These are all placed onto a 1:1 drawing sheet. After this, I have to go over each part and label things like edge for edging, 5deep for a 5mm deep groove, etc. I'd like to automate this somehow.
In the parts, I can add attributes to faces of grooves, edge of panels etc so would that work? For example: I set the rebated face as 5deep attribute and in the drawing, place a 5deep sketch symbol right on the centre of that face? Can that work?
If I attribute an edge that required edging, in a drawing you wouldn't see the actual edge face, you would only see the line of the edge. Can that still be picked up and have a sketch symbol place on the centre Point of the line?
All things are possible, are these possible?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
JelteDeJong
If you want to add sketch symbols (or any other feature with a leader and dimensions) then you need to find the intent. Acc. to the help files: "The GeometryIntent object represents a geometry intent for use in various annotation and view creations."  Creating these intent objects can be done with the following code if you have attributes on your faces/edges.
''' <summary>
''' </summary>
''' <param name="view">Drawing view of the model</param>
''' <param name="name">Attribute value</param>
''' <param name="Intent">
''' Input object that specifies the intent point on the input geometry.
''' This can be a value from PointIntentEnum, a geometry if the intent is the intersection of two geometries,
''' a Point2d object that specifies a sheet point on the geometry or a double value (0 to 1) indicating
''' the parameter on the input curve geometry. The range of valid parameter values can be obtained using
''' the GetParamExtents method on the curve's evaluator.  This Is an optional argument whose default value Is null.
''' </param>
''' <returns></returns>
Public Function GetIntent(view As DrawingView, name As String, Optional Intent As Object = Nothing) As GeometryIntent
    Dim model As Document = view.ReferencedDocumentDescriptor.ReferencedDocument
    Dim objs As ObjectCollection = model.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicProxyEntityNameSet", name)
    If (objs.Count <> 1) Then
        Throw New Exception(objs.Count & " object found with name: " & name)
    Dim obj = objs.Item(1)
    Dim curves = view.DrawingCurves(obj)
    If (curves.Count = 0) Then
        Throw New Exception("None DrawingCurve found for entity: " & name)
    Dim curve As DrawingCurve = curves.Item(1)
    Return view.Parent.CreateGeometryIntent(curve, Intent)
End Function
This code is taken from my blog post "Add function "GetProxyIntent()" to Ilogic".
Jelte de Jong
Blog: hjalte.nl - github.com
