Demote selected components by pick function to create new subassembly
Message 1 of 1
Hi guys...
It is possible to have a code similar to the one from Adam ( Demote Occurrence Pattern) but using pick function to select components and then demote them to a sub assembly?
The code from Adam is great but allows only a defined part to get demoted.
Would be great if someone can help with this.
For the pick function I believe the code from Adam (Do Selection from iLogic) is a great start but I have no idea how to used the selection to demote into an subassembly - or did someone knows a better way of doing this?
Thanks for you support as usual and special thanks again to MechMan
Jens
Replies (0)
