Deleting virtual components
Thomas.Long
Thomas.Long
So I have a bit of an oddity with virtual components. The same bit of code works just fine in some instances of my program and refuses to work in others.
I have an assembly that may or may not need virtual components. One particular name I'm sure I'll need gets ordered and deleted correctly. There seems to be no issues with it.
Another instance of my program the amount depends on what I have in the assembly and so if I remove parts it's supposed to go back and update the number of parts. The issue with this one is that if goes to 0, it doesn't delete the last virtual part. It always leaves exactly one if there are supposed to be none in the assembly. The oddity with this one is that the same exact function is used in the two different rules and works in one but not the other. I guess it works in one because I know I'll always need at least one of the components so it never actually attempts to have no instances of the virtual components in the assembly.
Function UpdateVirtParts (sVirtPart, Description, iQty)
	'define assembly
	Dim asmDoc As AssemblyDocument
	asmDoc = ThisApplication.ActiveDocument
	'define assembly Component Definition
	Dim oAsmCompDef As AssemblyComponentDefinition
	oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
	'Iterate through all of the occurrences in the assembly
	Dim asmOcc As ComponentOccurrence
	For Each asmOcc  In oAsmCompDef.Occurrences
		'get name of occurence only (sees only everything left of the colon)
		Dim oOcc As Object
		oOcc = asmOcc.Name.Split(":")(0)
		'look at only virtual components
		If TypeOf asmOcc.Definition Is VirtualComponentDefinition
			'compare name selected from list to the
			'existing virtual parts
			If oOcc = sVirtPart Then asmOcc.delete
	Next
	Dim occs As ComponentOccurrences
	occs = asmDoc.ComponentDefinition.Occurrences
	Dim identity As Matrix
	identity = ThisApplication.TransientGeometry.CreateMatrix
	'create first instance of the virtual part
	If iQTY > 0
		Dim virtOcc As ComponentOccurrence
		virtOcc = occs.AddVirtual(sVirtPart, identity)
		iProperties.Value(sVirtPart & ":1", "Project", "Description") = Description
		iProperties.Value(sVirtPart & ":1", "Project", "Part Number") = sVirtPart
		For index As Integer = 2 To iQTY
			occs.AddByComponentDefinition(virtOcc.Definition, identity)
		Next
End Function
The final instance is meant to purge the program of all virtual components because this one may have ordered different parts previously. The exact virtual component it needs will depend on the geometry of the assembly, so when I change it may end up needing a different part entirely. This one runs fine if there's no virtual components to delete, but the first time it checks for an actual virtual component and finds one, it errors.
Function PurgeVirtualComponents()
	'Iterate through all of the occurrences in the assembly and purge virtual components
		If TypeOf asmOcc.Definition Is VirtualComponentDefinition Then asmOcc.delete
	Next
End Function
This is the error in question: Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
Thank you,
Thomas Long
Thomas.Long
Apologies, I found out that I can bypass the error that was halting the program by adding an on error resume next, though I really would like to know why on earth its causing the error.
