Deleting sketch points in derived sketch
Jef_E
Jef_E
I am working on a 'configurator' for a tube heat exchanger. For this I generate a point cloud using XY coordinates. Then I add the points to a sketch in the 'Master' part. Lets say there are 500 points.
Then the sketch is derived to the tubesheet part and used by a hole feature that consumes all centermark points. Until here all is going great.
Now I am testing the ability to change the tubesheet hole pattern and adding holes is also working great, but when a smaller tubesheet pattern is generated there are more point in the base sketch in the master than in the derived sketch.
How can I delete these excessive points by code?
        Dim oPatternSketch As PlanarSketch = _Tubesheet.ComponentDefinition.Sketches.Item("Tubesheet pattern")
        Debug.Print(oPatternSketch.SketchPoints.Count)
        For Each oPoint As SketchPoint In oPatternSketch.SketchPoints
            Debug.Print(oPoint.HasReferenceComponent)
            Try
                oPoint.Delete()
            Catch ex As Exception
            End Try
        Next
I can delete them by hand just by selecting and press delete, but when I use the code above they are generating a error..
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
HideoYamada
Hello Jef_E,
Could you upload the minimum data set that cause error with your code written in the 1st post?
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Jef_E
You should update before trying to remove.. o wait thats my own questio lal
Inventor 2014 SP2
