Deleting/Replacing Sketch Symbols on multiple sheets in IDW
eugene.morales
eugene.morales
Hi All,
I've been looking for codes that can delete and replace a specific inserted sketch symbol in a drawing sheet or multiple sheet but I can only find something that I can insert a symbol. We use multiple sheets in an IDW and used the sketched symbols in every sheet. If there's a code that can do this task, it can reduce our work in a way and to be efficient. I'm not that savvy in coding and still learning slowly in this field. It will be much appreciated if someone can help me out.
A.Acheson
Can you post the code you are using for the insert of the symbol. Is the symbol held in the symbol library or a template sheet? The symbols library would be the best place to fetch this from.
Regards
Alan
eugene.morales
@A.Acheson
Hi, Thank you for your response to my inquiry but I've managed to find a code that would suit what we need. The code below lets me add them in all of my sheets and I've got the code to delete them also or I can specifically add symbols into my sheet using a form. The form contains buttons of every rule I've got to derive the series of symbols I need.
'----------------START OF iLOGIC CODE-----------------------------------
Sub main
    ' Set a reference to the drawing document.
    ' This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    oDrawDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    oSheet = oDrawDoc.ActiveSheet
	    ' Obtain a reference to the desired sketched symbol definition.
    Dim oSketchedSymbolDef As SketchedSymbolDefinition
    oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions.Item("IFA Stamp")
	'Check this is a drawing document...
If Not TypeOf ThisDoc.Document Is DrawingDocument Then
	MessageBox.Show("This rule will only run on a drawing", _
	"Realm", MessageBoxButtons.OK, MessageBoxIcon.Information)
	'Exit sub if not a drawing document
	Exit Sub
'Loop through sheets
For Each oSheet In oDrawDoc.Sheets
	'Loop through each symbol
	'For Each oSymbol In oSheet.SketchedSymbols
		'look for the symbol by name
   Dim oTG As TransientGeometry
    oTG = ThisApplication.TransientGeometry
    ' Add an instance of the sketched symbol definition to the sheet.
    ' Rotate the instance by 45 degrees and scale by .75 when adding.
    ' The symbol will be inserted at (0,0) on the sheet. Since the
    ' start point of the line was marked as the insertion point, the
    ' start point should end up at (0,0).
    Dim oSketchedSymbol As SketchedSymbol
    oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oTG.CreatePoint2d(9, 54.5), 0, 1, sPromptStrings)
Next
End Sub
'--------------------END OF iLOGIC CODE-----------------------------------
The code below can delete the symbol in all of the sheet.
Sub main
    Dim oSheet As Sheet
	Exit Sub
		If oSymbol.Name = "IFA Stamp" Then
			oSymbol.Delete
	Next
Next
End Sub
And this one will add the symbol to the current sheet.
'Sub Main()
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSketchedSymbolDef As SketchedSymbolDefinition _
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
'create insertion point, coordinates - in cm !
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim oInsertionPoint As Point2d = oTG.CreatePoint2d(9, 54.5)
' Rotate angle = 0 radians,
' scale = 1 when adding
' no prompt text
Dim oSketchedSymbol As SketchedSymbol _
       = oSheet.SketchedSymbols.Add( _
             oSketchedSymbolDef, _
             oInsertionPoint, _
             0, 1, Nothing)
'End Sub
Screenshot of my form below 😄
The following codes let me customize their orientation in the drawings sheets so it's automated and I don't need to reorient it's position whenever I insert a symbol.
I would like to share it and hopefully it can be helpful to others too.
