Message 1 of 12
Deleting flat pattern Bendlines OR Tangentlines
12:42 PM
Can anyone comment, suggest, advise if the following might be achieved --
We make quite a lot of components in sheet metal that are best described generically as a flat, followed by an arc, followed by a flat. These are manufactured either by pressing up a flange (giving a tight radius), or rolling between the extents of arc (giving a large radius). I hope the attached sketch illustrates.
If I create a flat pattern and save a dxf for laser cutting I can keep or delete both/either the bend lines or tangent lines. The thing is, if we press up a flange the fabricators want an etched bend line while if we want the rolled option they want etched tangent lines. If the dxf is imported into ACAD it can be manually modified accordingly.
But can "something" be done within Inventor from a set of rules to automatically identify if the radius is "small" so deleting the corresponding tangent lines keeping the bend line, or "large" so keeping the tangent lines and deleting the bend line.
Automation was a driving force behind introducing Inventor, so the powers that be are not keep seeing stuff apparently being "drawn" in ACAD.
Any takers??
Any takers??
