Deleting and adding custom properties
Message 1 of 10
Hi everyone!
Sometimes when I dowload 3D CAD models from manufacturer, dowloaded file have many useless properties and each one I have to delete and add my. I'm trying to write a vba macro to deleting and adding custom properties of *IPT and *.IAM files. I have problem with deleting. Why it is not working? Please help.
Private Sub DeleteButton_Click()
Dim oCustomPropertySet As Document
Set oCustomPropertySet = ThisApplication.ActiveDocument
Dim invCustomPropertySet As PropertySet
oCustomPropertySet = invCustomPropertySet.PropertySets.Item("Inventor User Defined Properties")
For Each oCustomPropertySet In invCustomPropertySet
oCustProp.Delete
Next
End Sub
Adam
Replies (9)
Message 2 of 10
j.romo
Try with this one
you can keep properties just filling the hello world with the name of the property to keep if not all of them will be gone
SyntaxEditor Code Snippet
'define custom property collection
oCustomPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
'look at each property in the collection
For Each oCustProp In oCustomPropertySet
'check for a property name that you don't want to delete
If Not oCustProp.name = "HelloWorld" Then
'delete the custom iProperty
oCustProp.Delete
Else
Next
Message 3 of 10
Thanks for answer but I still have Compile error: Invald use or property on:
Message 4 of 10
j.romo
I have used the code many times
What inventor are u using?
check my screencast
Message 5 of 10
Hmm, maybe it is not working because I'm writing macro in VBA editor, not in ILogic 🙂
Message 6 of 10
dgreatice
fix :
Dim oCustomPropertySet as PropertySet Set oCustomPropertySet = ThisApplication.ActiveDocument.PropertySets.Item("Inventor User Defined Properties") Dim oCustProp As Property
For Each oCustProp In oCustomPropertySet oCustProp.Delete Next End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
Message 7 of 10
Thanks! it's works great now!
Message 8 of 10
arkelec
infoMASU6
I was about to post to ask if this was possible.  I see that it is, but my skills in this area are weak.
Rather than start a new topic, could anyone post some pointers as to how I implement the process?
I have previously been able to add fan external rule & a form for accessing custom fields, but this was very much "monkey see-monkey do".
To start with, I'm not sure about the comment VBA vs iLogic.
Thanks in advance.
Message 9 of 10
arkelec
I found some code to point me in the right direction, but it didn't do exactly what I need, so I've started a new thread.
Message 10 of 10
snappyjazz
@dgreatice
Newbie here. I am running Inventor 2019. The compile error shows this method doesn't work anymore. Is there another way?
