Deleting a line (2nd Try)
I want to delete a line or lines by selecting with the mouse. Is there a simple way?
In vba of course. Any help please!
Ber
Message was edited by: BernaJeanne Message was edited by: BernaJeanne
Please explain the equivalent non-VBA workflow for what you want to accomplish.
Do you want to delete lines from a view or sketched symbol lines?
I don't think that you can "delete" lines from a created view. You should be able to hide the line or lines however. It would be equivalent to selecting the view line, right clicking and changing the visibility option.
I want to delete lines in the sketch mode. But before deleting it the properties like LENGTH & ANGLE are displayed.
Thanks you.
Ber
Can you be a little more specific about what you're expecting your command
to do. Is it just reporting the length and angle when a line is selected?
Or does it allow you to select multiple lines? If so, how does the length
and angle work with this?
Brian Ekins
Autodesk Inventor API
