Delete Workplanes (Exception form HRESULT: 0x80070057(E_INVALIDARG))
I have a form with a button.
I am trying to delete all workplanes in a part, but i get an exception?
Wrong Parameter.(Exception form HRESULT: 0x80070057(E_INVALIDARG))
if i click the button multible times the workplanes are deleted else only some are deleted.
what is wrong in this code. Please help with a workaround.
Running VBExpress 2010 and Inventor 2011
 Dim oApp As Inventor.Application
        oApp = GetObject(, "Inventor.Application")
        Dim oPartdoc As PartDocument
        oPartdoc = oApp.ActiveDocument
        Dim oWorkPlanes As WorkPlanes
        oWorkPlanes = oPartdoc.ComponentDefinition.WorkPlanes
        Dim i As Integer
        Dim oWorkplane As WorkPlane
        For i = 1 To oWorkPlanes.Count
            Try
                If i > 3 Then
                    oWorkplane = oWorkPlanes.Item(i)
                    'MsgBox(oWorkplane.Name)
                    oWorkplane.Delete()
            Catch ex As ArgumentException
                MsgBox(ex.Message)
                'GoTo DoThis
            Catch ex As Exception
                'MsgBox(ex.Message)
            Finally
            End Try
            'DoThis:
        Next
    End Sub
regards Kent boettger
YuhanZhang
The exception happens when you are going to get a work plane with an invalid index. Say you have 5 work planes, and the first 3 work planes are the built-in ones so you could not delete them, and you want to delete the last 2 custom work planes. And you use an index [i] for work plane, so when i = 4, you will delete the forth work plane, then the i will be 5, but because you deleted a work plane, now there are only 4 work planes, and index 5 is out of the range.
So solution can be like below, i.e. delete the work planes from the last one to the forth:
For i = oWorkPlanes.Count To 4
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
The code example you provided does not work, if i replace the code part.
'For i = 3 To oWorkPlanes.Count
nothing goes anymore? Please help on this issue
Regards.
Kent boettger
ekinsb
There are a few ways to approach this, but the issue is the one that was already described.  That is the contents of the collection are changing as you delete items and you need to take that into account when you use the Item property to get an object by index.
Here's a version of the program that works for me.  It's deleting the the 4th work plane for every iteration.
Public Sub DeleteWorkPlanes()
    Dim partDoc As PartDocument
    Set partDoc = ThisApplication.ActiveDocument
    Dim i As Integer
    For i = 4 To partDoc.ComponentDefinition.WorkPlanes.count
        Dim wp As WorkPlane
        Set wp = partDoc.ComponentDefinition.WorkPlanes.Item(4)
        wp.Delete
    Next
End Sub
Brian Ekins
Mod the Machine blog
YuhanZhang
Sorry for a mistake, that I should add a Step of -1 in that code, so correct code is as below:
For i = oWorkPlanes.Count To 4 Step -1
Also you can take use of Mr. Brian's method to delete the forth work plane every time.
Rocky Zhang
Inventor API PD
Autodesk, Inc.
Hello Brian and yuhanzhang, its always nice when you are around 🙂
I see the problem you describe.
My problem is actually that a have a part with 10 - 20 different workplanes.
Based on some input in my addin some of them has to be deleted.
I Figure the way I tried to approach this by running thru the workplanes until now is the wrong way.
I figure I have to make a selection set of the workplanes I need to delete, and the delete the workplanes I added to the selection set?
Here is an example: I have a part with 10 workplanes.
I want to count how many workplanes that are in the part, and then add - lets say "workplane 1" "Workplane 5" and Workplane 8" to a selection set, next I want to delete any workplane I added to the selection set.
Is this the right way?
Do you have a little code that shows how to do this?
Regards Kent Boettger
Thanks for your solutions, brian & yuhanzhang but after some thinking i ended up doing it this way, again thanks for your help Smiley Wink
If ComboIPlace.Text = "Top - left" Then
            oWorkplane = oWorkPlanes.Item("Work Plane6")
            oWorkplane.Delete(False)
            oWorkplane = oWorkPlanes.Item("Work Plane8")
            oWorkplane = oWorkPlanes.Item("Work Plane15")
            oWorkplane = oWorkPlanes.Item("Work Plane16")
            oWorkplane = oWorkPlanes.Item("Work Plane17")
            oWorkplane = oWorkPlanes.Item("Work Plane19")
