Delete Translation report
CadUser46
CadUser46
We have loads of imported files that have the translation report in the model browser under the 3rd Party browser node.  I'd like to delete it while doing some other housekeeping tasks but so far i cant figure out how this is done.  Trying to delete the browser nodes results in an error.  Any clues?
Cheers
Craig
Inventor 2010 Certified Professional
Currently using 2023 Pro
Vladimir.Ananyev
References to the embedded translation reports are stored in the ReferencedOLEFileDescriptors collection and could be deleted using ReferencedOLEFileDescriptor.Delete method:
Sub Test()
    Dim oDoc As PartDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDescr As ReferencedOLEFileDescriptor
    Set oDescr = oDoc.ReferencedOLEFileDescriptors.Item(1)
    Debug.Print "Display name: " & oDescr.DisplayName
    oDescr.Delete
End Sub
So it could be easily included into your workflow.
Best regards,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
CadUser46
Vladimir thank you.  Works perfect.
J.Classens
Hey,
This iLogc rule is exactly what i need.
I get the following error
Errror on line 3: Set instructions arren't longer supported
Errror on line 6: Set instructions arren't longer supported
Errror on line 8: Method argument must be in parentheses
I couldn't discover why the  set instruction isn't longer supported.
Anybody suggestions?
