delete to recycle bin
isocam
isocam
Can anybody help
I have the following Visual Basic.net code...
My.Computer.FileSystem.DeleteFile("F:\3DCAD\test.txt", FileIO.UIOption.OnlyErrorDialogs, FileIO.RecycleOption.SendToRecycleBin)
if the file "test.txt" was in the "C" drive (eg "C:\test.txt") it works OK.
Can anybody tell me why it does not work over the network????
Many thanks in advance!
ekinsb
I believe this is a limitation of Windows.  Deleting a network file permanently deletes it.  Try it interactively and you should see the same results.
Brian Ekins
Mod the Machine blog
