delete sketchpoints in part document automated
Message 1 of 1
Hello everybody,
I have a problem to delete some sketchpoints automated.
I need a closed area of two different sketches projected into a third one.Both projected sketches changes geometry by changing some parameters. To build the extrusion for the new variation I delete all sketchpoints first (pic. "after deleting without problem") and subsequently create them new. If the sketch is without problems it is working fine (pic. "created sketchpoints").
But if there are some parameter changing based problems inside the sketch, the code to delete the sketchpoints fails (pic. "after deleting with problem").
To fix the problem I do some manual deleting test. I got an message called: 'Autodesk Inventor Professional - Delete Selections' (pic. "error message while deleting sketchpoints manually"). The default button is 'Cancel'. After choosing 'Accept', the picked sketchpoint will be deleted.
Here is some code snipped out of my program - only the deleting part.
Dim oPartDoc As Document
oPartDoc = ThisApplication.ActiveDocument
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
Dim oSketches As PlanarSketches
oSketches = oCompDef.Sketches
Dim oSketch As PlanarSketch
oSketch = oSketches.Item("mid")
oSketch.Edit
'Dim oErrMgr As ErrorManager
'oErrMgr = ThisApplication.ErrorManager
'Dim oMessSec As MessageSection
'oMessSec = oErrMgr.StartMessageSection
Dim b, oCountEnd As Integer
b = 1
oCountEnd = 24
Dim oSkEntity As SketchEntity
For b = 1 To oSketch.SketchEntities.Count
	If b > oCountEnd Then
		oSkEntity = oSketch.SketchEntities.Item(oCountEnd + 1)
		If oSkEntity.Type = 83896576 Then
			On Error Resume Next
			'If oMessSec.HasErrors = True Then
			oSkEntity.Delete()
			'End If
Next
'after that create new SketchPoints to get a closed loop for Extrusion
oSketch.ExitEdit
InventorVb.DocumentUpdate()
I do a test using the ErrorManager but I does not get it working. My test is included in the code but commented out. I am not sure it is the right way.
Maybe changing the default button in the messagebox is a solution? How can I do this?
I am grateful for any help that points me in the right direction!
Greetings,
Jana
Replies (0)
