Delete Sick Joints / Constraint
Alexrose1942
Alexrose1942
 Using this guy code http://inventortrenches.blogspot.co.il/2013/01/ilogic-delete-all-sick-assembly.html, im deleting sick constraint quickly. (Thank you Curtis) what will be the addition to the code so it works for "sick joints" the same way ?
Dim oAssDoc As AssemblyDocument
oAssDoc = ThisApplication.ActiveDocument
Dim oConstraint As AssemblyConstraint
RUSure = MessageBox.Show _
("Are you sure you want to Delete all sick constraints?",  _
"iLogic",MessageBoxButtons.YesNo)
If RUSure = vbNo Then
Return
Else
          i = 0
          For Each oConstraint In oAssDoc.ComponentDefinition.Constraints
            If oConstraint.HealthStatus <> oConstraint.HealthStatus.kUpToDateHealth And _
            oConstraint.HealthStatus <> oConstraint.HealthStatus.kSuppressedHealth Then
          oConstraint.Delete
            i = i + 1
          Next
MessageBox.Show(" A total of "&  i & " constraints were deleted.", "iLogic")
Curtis_Waguespack
Hi Alexrose1942,
Although I didn't test it much, I think this example will handle sick constraints and sick joints.
I hope this helps.
Curtis
Dim oJoint As AssemblyJoint
("Are you sure you want to delete all sick Relationships?",  _
Return
Else
          i = 0
          For Each oJoint In oAssDoc.ComponentDefinition.Joints
            If oJoint.HealthStatus <> oJoint.HealthStatus.kUpToDateHealth And _
            	oJoint.HealthStatus <> oJoint.HealthStatus.kSuppressedHealth Then
          		oJoint.Delete
				i = i + 1
          Next
		  j = 0
          		oConstraint.Delete
				j = j + 1
          Next
MessageBox.Show(" A total of "&  i+j & " Relationships were deleted.", "iLogic")
Alexrose1942
Seems like it's working,smileysurprised:
can generally iLogic go deeper and search for those also in all subassemblies, I'm just asking as I'm very curious.
your code saved my day!
