Delete Pattern With Name
mark.almack
mark.almack
I have a rule to delete my suppressed patterns (see below), but can't figure out how to delete a pattern (and all its children) which has name "Terry"
I need something like
If oOcc.PatternElement.Parent.Name = "Terry
oOcc.Delete
Help Much Apreciated.
Sub Main()
	Dim oDoc as Document
	oDoc = ThisDoc.Document
	Dim oAsmCD As AssemblyComponentDefinition
	oAsmCD = oDoc.ComponentDefinition
	Dim oObjToDelete As Object
	On Error Resume Next
	Dim oOcc As ComponentOccurrence
	For Each oOcc in oAsmCD.Occurrences
		If oOcc.Suppressed = True
			oObjToDelete = GetAssyLevelItemToDelete(oOcc)
			oObjToDelete.Delete
			oOcc.Delete
	Next
End Sub
Function GetAssyLevelItemToDelete(oOcc As Object) As Object
	If oOcc.IsPatternElement
		oOcc = oOcc.PatternElement.Parent
		oOcc = GetAssyLevelItemToDelete(oOcc)
	Return oOcc
End Function
WCrihfield
Would something like this work for you?
One thing I'm thinking might go wrong, is that it might not let you delete the initial (source) component of a pattern, without deleting the pattern.  If so, you may be able to check the Index of the element (as I started to do) to make sure you delete all but the first one, then if you still can't delete the last component, just delete the parent pattern first, then you will likely be able to delete that last pesky component.
If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
	MsgBox("An Assembly Document must be active for this rule (" & iLogicVb.RuleName & ") to work. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
	Exit Sub
Dim oADoc As AssemblyDocument = ThisAssembly.Document
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
For Each oOccPatt As OccurrencePattern In oADef.OccurrencePatterns
	If oOccPatt.Name = "Terry" Then
		For Each oOccPattElmt As OccurrencePatternElement In oOccPatt.OccurrencePatternElements
			'If oOccPattElmt.Index > 1 Then
			oOccPattElmt.Occurrences.Item(1).Delete
		Next
		oOccPatt.Delete
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click 'LIKE' 👍.
If you have time, please... Vote For My IDEAS 💡or you can Explore My CONTRIBUTIONS
Inventor 2021 Help | Inventor Forum | Inventor Customization Forum | Inventor Ideas Forum
Wesley Crihfield
(Not an Autodesk Employee)
