Delete Model State via iLogic
zoe.baker-bushby
zoe.baker-bushby
Wanting iLogic rule that will clear off all model states except the current active one aka the Master.
Understand there is this syntax:
ModelState.Delete()
But can not seem to get this to work...
Heres what I have:
Dim doc As AssemblyDocument = ThisDoc.Document
oName = "COURSE 1 STEEL TANK SHEET:8"
occ = doc.ComponentDefinition.Occurrences.ItemByName(oName)
Dim facDoc As PartDocument = occ.Definition.Document
oPCD = facDoc.ComponentDefinition
oMStates = oPCD.ModelStates
Component.ActiveModelState("COURSE 1 STEEL TANK SHEET:8") = "Master"
For Each STATE In oMStates
	MessageBox.Show(STATE.Name)
	If STATE.Name = "Model State1"
'		Delete Model State
Next
iLogicVb.UpdateWhenDone() = True
Any help would be great, thanks.
CattabianiI
You've done the most common mistake when working with model states: forgetting about the factory document, which I know it's a very tricky concept.
Here's the solution:
' Get the factory document, it's from the factory where you
' can delete and do some other impacting operations Dim facDoc As PartDocument = occ.Definition.FactoryDocument
' Sometimes you could have to open explicitly the factory, but ignore this step at the moment oPCD = facDoc.ComponentDefinition oMStates = oPCD.ModelStates
' Activate the master model state in the factory, to be sure you can delete the custom ones
Dim masterMs As ModelState = oMStates.Item("Master")
masterMs.Activate()
' Activate the master model state in the occurrence Component.ActiveModelState("COURSE 1 STEEL TANK SHEET:8") = "Master"
' Loop through factory model states For Each STATE In oMStates MessageBox.Show(STATE.Name) If STATE.Name = "Model State1" ' Delete Model State
STATE.Delete() End If Next iLogicVb.UpdateWhenDone() = True
