Delete iProperties ilogic
sebastian.muschler
sebastian.muschler
Hi everyone!
I am currently trying to write an ilogic script with which I can delete all user parameters and all user-specific iProperties in the assemblies and in the parts. The user-specific parameters are deleted with the ilogic, but the iProperties are not, I just can't get them deleted
Perhaps someone here can help me with what I am doing wrong here.
many thanks in advance
Sub Main
    Dim invApp As Application
    invApp = ThisApplication
    ' Aktive Baugruppe holen
    Dim doc As AssemblyDocument
    If TypeOf invApp.ActiveDocument Is AssemblyDocument Then
        doc = invApp.ActiveDocument
    Else
        MsgBox ("Bitte eine Baugruppe öffnen!")
        Exit Sub
    ' Benutzerparameter in deren Baugruppe löschen
    DeleteUserParameters(doc)
    ' iProperties in der Baugruppe löschen
    DeleteAlliProperties(doc)
    ' Alle Bauteile in der Baugruppe durchlaufen
    Dim compDef As AssemblyComponentDefinition
    compDef = doc.ComponentDefinition
    Dim oOccurrence As ComponentOccurrence
    For Each oOccurrence In compDef.Occurrences
        If oOccurrence.DefinitionDocumentType = kPartDocumentObject Then
            Dim partDoc As PartDocument
            partDoc = oOccurrence.ReferencedDocumentDescriptor.ReferencedDocument
            DeleteUserParameters(partDoc)
            DeleteAlliProperties(partDoc)
    Next
    MsgBox("Alle Benutzerparameter und iProperties wurden gelöscht!")
End Sub
Sub DeleteUserParameters(ByVal doc As Document)
    On Error Resume Next
    Dim params As UserParameters
    params = doc.ComponentDefinition.Parameters.UserParameters
    Dim i As Integer
    For i = params.Count To 1 Step -1
        params.Item(i).Delete
    Next i
    On Error GoTo 0
End Sub
Sub DeleteAlliProperties(ByVal doc As Document)
    Dim propSets As PropertySets
    propSets = doc.PropertySets
    ' Alle iProperties (Standard und Benutzerdefiniert) durchlaufen
    Dim propSet As PropertySet
    Dim prop As Inventor.Property
    Dim i As Integer
    For Each propSet In propSets
        ' Für jede PropertySet durchlaufen
        For i = propSet.Count To 1 Step -1
            prop = propSet.Item(i)
            ' Überprüfen, ob die iProperty nicht schreibgeschützt ist
            If Not prop.ReadOnly Then
                ' iProperty löschen
                propSet.Remove (i)
        Next i
    Next propSet
    On Error GoTo 0
End Sub
swalton
I've asked the forum mods to move this post to the Inventor programming forum.  I believe the folks over there will be able to help.
See: https://forums.autodesk.com/t5/inventor-programming-ilogic/bd-p/120
Steve Walton
Inventor 2025
Vault Professional 2025
kacper.suchomski
Hi
Will this help you? (iProperties in active document)
' Aktives Dokument abrufen
Dim oDoc As Document = ThisApplication.ActiveDocument
' Überprüfen, ob ein Dokument geöffnet ist und iProperties unterstützt
If oDoc Is Nothing Then
    MessageBox.Show("Kein aktives Dokument gefunden.", "Fehler", MessageBoxButtons.OK, MessageBoxIcon.Error)
    Return
' Benutzerdefinierte Eigenschaften abrufen
Dim customProps As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
' Alle benutzerdefinierten Eigenschaften löschen
Dim propCount As Integer = customProps.Count
For i As Integer = propCount To 1 Step -1
    customProps.Item(i).Delete()
Next
' Erfolgsnachricht anzeigen
MessageBox.Show("Alle benutzerdefinierten iProperties wurden gelöscht.", "Erfolg", MessageBoxButtons.OK, MessageBoxIcon.Information)
Kacper Suchomski
sebastian.muschler
Hallo Kacper,
thank you, yes that helped me a lot. It does exactly what it's supposed to do. 👍
 	Sub Main
    Else
        Exit Sub
    Next
End Sub
    Dim i As Integer
    Next i
    On Error GoTo 0
End Sub
Dim customProps As PropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
Next i
    On Error GoTo 0
End Sub
All iProperties in the assembly and in the sub-assemblies and parts are now deleted as required
