Delete Features and Sketches
I'm trying to create a code that deletes all the sketches in a part. I'd also like to delete all the features  and their consumed sketches as well. I'm using the below code to try and delete the sketches. It runs without error but also doesn't delete anything.
SyntaxEditor Code Snippet
Sub Main()
Dim oPartDoc As PartDocument
        oPartDoc = ThisApplication.ActiveDocument
Dim oPartDef As PartComponentDefinition
        oPartDef = oPartDoc.ComponentDefinition
Dim sketch1 As Sketch3D
For Each sketch1 in oPartDef.Sketches
    sketch1.Delete
Next
End Sub
The sketches are all named sketches created using a different code.
Owner2229
Hi, try this one:
Sub Main()
' Get Document and Definition Dim oDoc As Document = ThisApplication.ActiveDocument Dim oCD As ComponentDefinition= oDoc.ComponentDefinition
' Delete Features Dim oFeat As PartFeature For Each oFeat In oCD.Features oFeat.Delete Next
' Delete Sketches Dim oSketch As PlanarSketch For Each oSketch in oCD.Sketches oSketch.Delete Next End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Thank you for the help. That works great.
What if I want to delete a specific named sketch?
For example if I have
Dim oSketch1 As Inventor.PlanarSketch
    oSketch1 = oPartDef.Sketches.Add(oPartDef.WorkPlanes(2))
        oSketch.Name = "Feature Sketch"
Is there a way to just delete the sketch titled Feature Sketch?
Owner2229
' Delete Sketch by name Dim oSketch As PlanarSketch = oCD.Sketches.Item("Feature Sketch") oSketch.Delete
Mike
Can this be used just to activate the sketch?
Or delete a sketch and recreate one?
Owner2229
Hey, to activate a Sketch you can use this:
oSketch.Edit()
To exit the editing you can use this:
oSketch.ExitEdit()
But to create new sketch you need a face or plane to add the sketch on. E.g. like in acurtinT3UX6's sample above:
Dim oSketch As Inventor.PlanarSketch
oSketch = oPartDef.Sketches.Add(oPartDef.WorkPlanes(2)) oSketch.Name = "Feature Sketch"
Mike
