Delete excel Documents from your project folder
ndillner343SKL
ndillner343SKL
I'm looking to delete an excel document (.xlsx) from my project folder.
This is my best attempt,
	'define the file to create/open
	myXLS_File = ThisDoc.Path & "\TempFile.xlsx"
'define Excel Application object
	excelApp = CreateObject("Excel.Application")
'set Excel to run visibly, change to false if you want to run it invisibly
	excelApp.Visible = False
'suppress prompts (such as the compatibility checker)
	excelApp.DisplayAlerts = False
	excelWorkbook = excelApp.Workbooks.Delete(myXLS_File)
basautomationservices
if this is iLogic:
If System.IO.File.Exists(myXLS_File) Then
    System.IO.File.Delete(MyXLS_File)
End if
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
JelteDeJong
In addition on @basautomationservices reply. You can use the function IO.Path.Combine(...) This function will add \ in your path if needed. (I see that you hard coded them in your OP) Because that function will look automatically for you if \ are needed it's less likely for you to get bugs.
Another thing I like is the FileInfo class. It has all kinds functions that you might need. Your could could look like this.
[iLogic code]
Dim excelFilePath = System.IO.Path.Combine(ThisDoc.Path, "TempFile.xlsx")
Dim excelFileInfo As New System.IO.FileInfo(excelFilePath)
If (excelFileInfo.Exists) Then excelFileInfo.Delete()
Jelte de Jong
Blog: hjalte.nl - github.com
