Delete all unattached centerlines and dimensions
I found this sample. But how could I delete all the unattached centerlines?
Public Sub DeleteUnattachedDimensions()
' Set a reference to the active drawing document
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oDrawingDim As DrawingDimension
' Iterate over all dimensions in the drawing
' and delete unattached (sick) dimensions.
For Each oDrawingDim In oSheet.DrawingDimensions
If oDrawingDim.Attached = False Then
Call oDrawingDim.Delete
Next
End Sub
Best regards
Georg
Centerlines aren't currently exposed by the API so there isn't any way of
doing this. This is a known issue that we plan to address in the future.
Brian Ekins
Autodesk Inventor API
"GeorgK" wrote in message
news:5244235@discussion.autodesk.com...
Dim oSheet As Sheet
Next
End Sub
Best regards
Georg
I used the Inventor transcript and got this:
ActiveDocument.Execute("Document1","DeleteEmblem","Emblems_Count=1;Emblems_0=Document1.DLSheet577DCSegment.296;")
Is it possible to get the name of the unused centerlines?
Best regards
Georg
