04:10 AM
After a year of reasearching iParts and iAssemblies i want to contribute to the community with some code i use.
If in a Ipart/Iassembly Factory you assign an event trigger to a rule, the event triggers are also assigned to its members but the rules aren't, so you get annoying messeges.
So to delete ALL triggers in the assembly(Parts,Assemblies,Iparts and Iasseblies ) i made this rule:
SyntaxEditor Code Snippet
Sub Main Auto = iLogicVb.Automation Dim iLogicAuto As Object iLogicAuto = Auto Call deletecurrent() Dim oDoc As Document oDoc = ThisApplication.ActiveDocument Dim oCompDef As Inventor.ComponentDefinition = oDoc.ComponentDefinition Dim occ As ComponentOccurrence For Each occ In oCompDef.Occurrences isum=isum+1 Next For i=1 To isum occ = oDoc.ComponentDefinition.Occurrences(i) If occ.Name="" Then Goto 1: occDocument= occ.Definition.Document asm = ThisApplication.Documents.Open(occ.Definition.Document.fullfilename,False) Call RemoveRulesfromEventTrigger(occ) asm.Close(True) If occDocument.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then If occ.Definition.IsiPartMember Then factoryDoc = occ.Definition.iPartMember.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName asm = ThisApplication.Documents.Open(factoryDoc,False) Call RemoveRulesfromEventTriggerIpart(occ) asm.Close(True) End If End If If occDocument.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then If occ.Definition.IsiAssemblyMember Then factoryDoc = occ.Definition.iAssemblyMember.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName asm = ThisApplication.Documents.Open(factoryDoc,False) Call RemoveRulesfromEventTriggerIAssembly(occ) asm.Close(True) End If Call ProcessFactoryFile(occ) End If 1: Next End Sub Sub ProcessFactoryFile ( occ As ComponentOccurrence) oDoc = occ.Definition.Document Dim oCompDef As Inventor.ComponentDefinition = oDoc.ComponentDefinition Dim Subocc As ComponentOccurrence isum=0 For Each Subocc In oCompDef.Occurrences isum=isum+1 Next For i=1 To isum subocc = oDoc.ComponentDefinition.Occurrences(i) suboccDocument= subocc.Definition.Document If subocc.Name="" Then Goto 1: asm = ThisApplication.Documents.Open(subocc.Definition.Document.fullfilename,False) Call RemoveRulesfromEventTrigger(subocc) asm.Close(True) If suboccDocument.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then If subocc.Definition.IsiPartMember Then factoryDoc = subocc.Definition.iPartMember.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName asm = ThisApplication.Documents.Open(factoryDoc,False) Call RemoveRulesfromEventTriggerIpart(subocc) asm.Close(True) End If End If If suboccDocument.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then If subocc.Definition.IsiAssemblyMember Then factoryDoc = subocc.Definition.iAssemblyMember.ReferencedDocumentDescriptor.ReferencedDocument.FullFileName asm = ThisApplication.Documents.Open(factoryDoc,False) Call RemoveRulesfromEventTriggerIAssembly(subocc) asm.Close(True) End If Call ProcessFactoryFile(subocc) End If 1: Next End Sub Sub RemoveRulesfromEventTrigger(occ As ComponentOccurrence) 'On Error Resume Next Auto = iLogicVb.Automation Dim iLogicAuto As Object iLogicAuto = Auto Dim oiLogicDoc As Document 'capture current document oiLogicDoc = occ.Definition.Document 'load up ilogic automation Dim oiLogicAuto As Object = iLogicVb.Automation 'get container for all of the ilogic rules Dim oRules As Object = oiLogicAuto.rules(oiLogicDoc) 'variable for the events rules Dim oiLogicPropSet As PropertySet 'set up a counter Dim iPropCount As Integer Try 'set our property set since we know it exists now oiLogicPropSet = oiLogicDoc.PropertySets.Item("{2C540830-0723-455E-A8E2-891722EB4C3E}") 'oiLogicPropSet = oiLogicDoc.PropertySets.Item("iLogicEventsRules") Dim strDeletedTriggers As String 'iterate through the triggers And delete Each If Not oiLogicPropSet.Count=0 Then For i As Integer = oiLogicPropSet.Count To 0 Step -1 oiLogicPropSet.Item(i).Delete Next i End If Catch End Try End Sub Sub RemoveRulesfromEventTriggerIpart(occ As ComponentOccurrence) 'On Error Resume Next factorydoc=occ.Definition.iPartMember.Parentfactory Auto = iLogicVb.Automation Dim iLogicAuto As Object iLogicAuto = Auto Dim oiLogicDoc As Document 'capture current document oiLogicDoc =occ.Definition.iPartMember.ReferencedDocumentDescriptor.ReferencedDocument 'load up ilogic automation Dim oiLogicAuto As Object = iLogicVb.Automation 'get container for all of the ilogic rules Dim oRules As Object = oiLogicAuto.rules(oiLogicDoc) 'variable for the events rules Dim oiLogicPropSet As PropertySet 'set up a counter Dim iPropCount As Integer Try 'set our property set since we know it exists now oiLogicPropSet = oiLogicDoc.PropertySets.Item("{2C540830-0723-455E-A8E2-891722EB4C3E}") 'oiLogicPropSet = oiLogicDoc.PropertySets.Item("iLogicEventsRules") Dim strDeletedTriggers As String 'iterate through the triggers And delete Each If Not oiLogicPropSet.Count=0 Then For i As Integer = oiLogicPropSet.Count To 0 Step -1 oiLogicPropSet.Item(i).Delete Next i End If Catch End Try End Sub Sub RemoveRulesfromEventTriggerIAssembly(occ As ComponentOccurrence) 'On Error Resume Next factorydoc=occ.Definition.iAssemblyMember.Parentfactory Auto = iLogicVb.Automation Dim iLogicAuto As Object iLogicAuto = Auto Dim oiLogicDoc As Document 'capture current document oiLogicDoc =occ.Definition.iAssemblyMember.ReferencedDocumentDescriptor.ReferencedDocument 'load up ilogic automation Dim oiLogicAuto As Object = iLogicVb.Automation 'get container for all of the ilogic rules Dim oRules As Object = oiLogicAuto.rules(oiLogicDoc) 'variable for the events rules Dim oiLogicPropSet As PropertySet 'set up a counter Dim iPropCount As Integer Try 'set our property set since we know it exists now oiLogicPropSet = oiLogicDoc.PropertySets.Item("{2C540830-0723-455E-A8E2-891722EB4C3E}") 'oiLogicPropSet = oiLogicDoc.PropertySets.Item("iLogicEventsRules") Dim strDeletedTriggers As String 'iterate through the triggers And delete Each If Not oiLogicPropSet.Count=0 Then For i As Integer = oiLogicPropSet.Count To 0 Step -1 oiLogicPropSet.Item(i).Delete Next i End If Catch End Try End Sub Sub deletecurrent() On Error Resume Next Auto = iLogicVb.Automation Dim iLogicAuto As Object iLogicAuto = Auto Dim oiLogicDoc As Document 'capture current document oiLogicDoc = ThisApplication.ActiveDocument 'load up ilogic automation Dim oiLogicAuto As Object = iLogicVb.Automation 'get container for all of the ilogic rules Dim oRules As Object = oiLogicAuto.rules(oiLogicDoc) 'variable for the events rules Dim oiLogicPropSet As PropertySet 'set up a counter Dim iPropCount As Integer 'set our property set since we know it exists now oiLogicPropSet = oiLogicDoc.PropertySets.Item("{2C540830-0723-455E-A8E2-891722EB4C3E}") 'oiLogicPropSet = oiLogicDoc.PropertySets.Item("iLogicEventsRules") Dim strDeletedTriggers As String 'iterate through the triggers And delete Each For i As Integer = oiLogicPropSet.Count To 0 Step -1 oiLogicPropSet.Item(i).Delete Next i End Sub
