delete all custom iProperties from drawing
fabimann
Message 1 of 9
fabimann
I'd like to delete all custom iProperties from a drawing which I've opened. I tried to adapt this:
https://forums.autodesk.com/t5/inventor-forum/how-to-remove-custom-iproperty-with-ilogic/td-p/436406...
It works fine for Parts but not for drawings. Can anyone help?
Fabian
Replies (8)
Message 2 of 9
dalton98
That code should work for any document, so I'm assuming you want to delete the custom properties of the assembly from a drawing document?
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oView As DrawingView
oView = oDrawingDoc.ActiveSheet.DrawingViews.Item(1)
Dim oDoc As Document
oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
'define custom property collection
oCustomPropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
'look at each property in the collection
For Each oCustProp In oCustomPropertySet
'delete the custom iProperty
oCustProp.Delete
Next
Message 3 of 9
fabimann
Hello @dalton98,
thank you for the quick reply. The code does work as you intended, but it is not was I was looking for. I want to delete all custom iProperties from an idw file. How should the code be adapted?
Best regards
Fabian
Message 4 of 9
dalton98
It worked for me. Try changing it from thisdoc to active document:
Dim oCustomPropertySet As PropertySet
oCustomPropertySet = oDrawingDoc.PropertySets.Item("Inventor User Defined Properties")
Dim oCustProp As Inventor.Property
oCustProp.Delete
Next
Message 5 of 9
fabimann
@dalton98
It still doesn't remove the custom iProperties from the idw file. Are there any restrictions or modifications to be made as I'm using a german version of Inventor?
Message 6 of 9
dalton98
Ohhh. Try changing this maybe.
oCustomPropertySet = oDrawingDoc.PropertySets.Item(4)
Message 7 of 9
fabimann
Hi @dalton98
sorry for the late reply, it took me some time to figure things out:
I used a script to create iProperties in a idw file, which worked fine. With another script I wanted to delete all iProperties within the idw file, which didn't work.
The problem seem to be the names of my iProperties. If they start with an underscore (for example "_S_M40_PROJEKTBEZEICHNUNG") they can't be deleted with a script, also they are not shown in the list of custom iProperties in the iLogic forms. Although the import-script works just fine.
I'm using Inventor 2020, is that a known problem?
Are there any other restrictions regarding the names of custom iProperties?
Best regards
Fabian
Message 8 of 9
dalton98
The only time I have a problem deleting iproperties is when the I'm working outside the part's project file, but it will throws an error explaining that.
I'm assuming the hidden property is giving you the error. You can try a try/catch or 'On Error Resume Next' to skip it. But then again that's probably the one you want deleted.
Message 9 of 9
fabimann
@dalton98
I deleted the iProperties manually and changed my naming scheme in the Excel file to avoid further problems.
Thanks for your effort, much appreciated
Fabian
