Define material-iProperty in VBA userform
uw
Message 1 of 9
uw
Hello!
I have designed a VBA-code which starts a userform with textboxes to fill in iProperties for the active project.
No problem so far.
But for defining the material-iProperty it would be perfect to have a combobox to select the material from the active material-database.
(To have an option for selecting the material-database would be great)
Thank you for any help you can offer!
 Reinhard
Replies (8)
Message 2 of 9
marcin_otręba
Adding all mat librarys:
 For i = 1 To g_inventorApplication.AssetLibraries.Count
            mat_lib(i)=g_inventorApplication.AssetLibraries.Item(i).DisplayName
  Next
Adding materials from mat lib:
Dim assetLib As AssetLibrary
 assetLib = g_inventorApplication.AssetLibraries.Item("materialy")
For i = 1 To assetLib.MaterialAssets.Count
                      mats_inv(i) = assetLib.MaterialAssets.Item(i).DisplayName.ToString
            Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 9
uw
Hello.
Please be lenient with me, buit I'm far away from being an VBA-expert...
I tried following code (called by a combobox of a userform):
_______________________________________________
Private Sub ComboBox1_Change()
    Dim i As Integer
    Dim mat_lib(1 To g_inventorApplication.AssetLibraries.Count) As Variant
            mat_lib(i) = g_inventorApplication.AssetLibraries.Item(i).DisplayName
        Next
    UserForm1.ComboBox1.List = mat_lib()
End Sub
There is no error or warning, but the list is empty:
Even though there are material-libaries in my project:
 Reinhard
Message 4 of 9
marcin_otręba
try:
    Dim i As Integer
    Dim mat_lib(g_inventorApplication.AssetLibraries.Count) As string
        Next
End Sub
Message 5 of 9
uw
Hello!
Thank you for your answer and your patience, but I'm affraid the solution is not working..
(Maybe I use your solution in a wrong way...)
In Inventor2019 I created a new ipt-file and with Alt+F11 I startet the VBA-environment.
I created a new UserForm with a ComboBox:
With a doubleclick on the ComboBox I started the code-environment and entered following code:
With F5 I tried to test the code, and the combobox was still empty:
 Reinhard
Message 6 of 9
marcin_otręba
Replace g_inventorApplication with thisapplication.
Net post if aby error occur Please place screen with error message
Message 7 of 9
uw
Hello.
No error messages but also no changes in the ComboBox - it is still empty Smiley Sad
Regards
 Reinhard
Message 8 of 9
marcin_otręba
hi,
Sorry i was writing from my mobile and focused on code, did't realise that you put code in wrong sub:
should bin in for initialize sub
try this instead:
Private Sub UserForm_Initialize()
    Dim i As Integer
    Dim mat_lib() As String
        For i = 1 To ThisApplication.AssetLibraries.Count
         ReDim Preserve mat_lib(i)
            mat_lib(i - 1) = ThisApplication.AssetLibraries.Item(i).DisplayName
        Next
End Sub
End Sub
Message 9 of 9
uw
Thank you very, very much!!!
It works:
But when I try to fill a ComboBox with the materials of a certain libary (e.g. "Inventor-Materialbibliothek")
with following code:
Dim i As Integer
assetLib = g_inventorApplication.AssetLibraries.Item("Inventor-Materialbibliothek")
Next
End Sub
I get following error-message:
Unfortunately (for you Smiley Wink) the message is in german.
It means something like "improper use of a property"
I hope you can help me one more time...
Thank you and have a nice evening!
Regards
 Reinhard
