Default Table Formatting
a81383
a81383
How do I change set the "Use Default Formatting" setting when creating my custom table shown below?
Thank you!
	Dim oCustomTable As CustomTable
	oCustomTable = oSheet.CustomTables.Add("SPEC", oPlacementPoint1, 2, cnt, oTitles, oContents, oColumnWidths)
	oCustomTable.HeadingPlacement = HeadingPlacementEnum.kHeadingAtBottom
	oCustomTable.ShowTitle = True
WCrihfield
I do not believe we have access to that setting through the Inventor API yet.  We can set TextStyle to various portions of the table, we can set the TableStyle, and even TableFormat, but none of them include that setting.  And the Colums & Column objects do not offer anything like that either.
Wesley Crihfield
(Not an Autodesk Employee)
a81383
Got it. I figured that was probably the case. I really appreciate your response. I will look into creating a new table style and swapping between the two.
Thank you!
