Default SheetMetal rules on body
patrice.vallet
patrice.vallet
I need your help.
I have a sheet metal part where I derive a body from another part and customize it.
My problem is when I update the part there is an error on my flatpattern, and in the sheetmetal rules on the body, the option "follow the default values" is untick.
I have to tick manually this option to fix my problem, but I need to automatize it with Ilogic.
I know how to change the sheetmetal rule on a body by Ilogic, but not tick this option.
Can you help me to write this Ilogic code ?
Thanks you
Ralf_Krieg
Hello
Can you please tell which version of Inventor you use?
R. Krieg
RKW Solutions
www.rkw-solutions.com
patrice.vallet
I'm using Inventor 2019.4.1
Ralf_Krieg
Hello
I was a little bit confused about the dialog. I couldn't find it. After some digging around I found it.
Can you try following:
Dim oApp As Inventor.Application= ThisApplication
Dim oPartDoc As PartDocument = oApp.ActiveDocument
Dim oCompDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
Dim oFeatures As SheetMetalFeatures = oCompDef.Features
Dim oFaceFeature As FaceFeature
For Each oFaceFeature In oFeatures.FaceFeatures
    If oFaceFeature.Definition.UseDefaultSheetMetalRule = False Then oFaceFeature.Definition.UseDefaultSheetMetalRule = True
Next
R. Krieg
RKW Solutions
patrice.vallet
Hello Krieg,
Your solution works great. It will help me a lot.
Thanks you
b.mccarthy
@Ralf_Krieg
Hello.
I have a similar problem with random parts where this setting gets unchecked. This code works great on standard folded sheet. However, in those cases where a sheet is derived (to create a left and right version) and the setting gets turned off, the rule will throw this error:
Line 10:
When this happens, I must manually reset it.
Any idea why this occurs, and how to repair it?
Thank you.
Maxim-CADman77
The code discussed is not applicable to those SheetMetal parts done with Derived Part because they don't have FaceFeatures (or any of the three types of SheetMetal Features that do have 'UseDefaultSheetMetalRule' property).
The best I can think of is to select the body and use CommandManager to open the Form shown in the start message of the topic where user is supposed to enable the "Follow Defaults" option and close the form with 'OK' button which is non-professional.
But maybe @johnsonshiue or @MjDeck can suggest the better way?
Please vote for Inventor-Idea Text Search within Option Names
