Default BOM Structure get a line in my code to fail
Darkforce_the_ilogic_guy
Advisor Advisor
I have a very complete code. That normaly work... But that change if just one iam is set to Phantom in Default BOM Struture.
the code that fail is this line
strFileName = brow.ReferencedFileDescriptor.FullFileName
I use it later in this line
oDate1 = oFS.GetFile(strFileName).DateLastModified
what i want to know is why is it fail and is there a workaround to fix it ?
I look like i have fix it with the code below .. but because of the complex natur of my code ... it is really harde to see if that is any way it can cause error in my data output I get by running the code.
Try
debug(strFileName & " error did not happen")
Catch
debug(strFileName + " error happen")
end try
jjstr8
What defines 'brow'?
WCrihfield
Hi @Darkforce_the_ilogic_guy.  I initially had the same question...but I guessed that it represented a BOMRow object.  If that is the case, the online help page for its ReferencedFileDescriptor property says that it "only applies to non merged component rows and non local components and immediately referenced components. Therefore this would only be useful in the data view."  It may be better to use its ComponentOccurrences property to access its first ComponentOccurrence object, then access its ReferencedDocumentDescriptor, then its FullDocumentName.  Or go through the BOMRow.ComponentDefinitions.Item(1).Document.FullFileName.
By the way...what is the error message saying?  That may help us understand how to fix or handle the error.  There is usually something useful on the More Info tab of the error message, but you may need to translate it to English for us.
Wesley Crihfield
(Not an Autodesk Employee)
This part of the code might help to see what brow is
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
oBOM.StructuredViewEnabled = True
oBOM.StructuredViewFirstLevelOnly = False
oBOM.StructuredViewDelimiter = "."
oBOM.PartsOnlyViewEnabled = True
Dim oBOMView As BOMView
oBOMView = oBOM.BOMViews.Item("Structured")
debug("Call ExportToExcel")
Call ExportToExcel(oBOMView.BOMRows)
'Add to Clipboard(Copy & past fuction)
Clipboard.SetText(oHoleRepport)
Clipboard.SetText(oHoleRepportExcel)
End Sub
Public Sub debug(txt As String)
	Trace.WriteLine("NTI : " & txt)
End Sub
Public Function ExportToExcel(brows As BOMRowsEnumerator)
Dim brow As BOMRow
For Each brow In brows
 the hole code is about 637 lines and not the best writte .. sind I am not a programmer( not a very good one ) .. so it mush design by try and error untill it  works 🙂 and have not have the time til clear it up
jjstr8
I'm not sure what the overall goal of your code is, but can you use the Model ("Unnamed") BOM?  The problem is that Inventor hides phantom components in the Structured and Parts Only BOMs.  In your case,  your phantom assembly has normal or purchased sub-components, so Inventor includes those as "promoted".  Unfortunately, the ReferencedFileDescriptor value does not get promoted, causing the exception when accessed.  The only way to see phantom components as a BOMRow is in BOMView.Item("Unnamed").
