Datagridview error when using Escape key to undo
magicdl96
magicdl96
I've had a few difficulties with the datagridview. I have a project written in VB.Net, I want in Datagridview, when I change a certain cell will check for duplicates or not. If has, will not change it and return old data.
But I can't use the Esc key to cancel editing and return old data. If my code used for the Form is not in Inventor it will work. But the Form used in the inventor is not.
My code is as follows:
Public Class Form1
    Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
        DataGridView1.Rows.Add("1", False, "11")
        DataGridView1.Rows.Add("2", False, "12")
        DataGridView1.Rows.Add("3", False, "13")
        DataGridView1.Rows.Add("4", False, "14")
    End Sub
    Private Sub DataGridView1_CurrentCellDirtyStateChanged(sender As Object, e As EventArgs) Handles DataGridView1.CurrentCellDirtyStateChanged
        DataGridView1.CommitEdit(DataGridViewDataErrorContexts.Commit)
    End Sub
    Private Sub DataGridView1_CellValidating(sender As Object, e As DataGridViewCellValidatingEventArgs) Handles DataGridView1.CellValidating
        Dim i As Integer = 0
        Dim namecolumn As String = "Name1"
        If DataGridView1.Rows(e.RowIndex).Cells(namecolumn).Value Is Nothing Then
            e.Cancel = True
            MsgBox("Please type name.")
        Else
            Do While (i < DataGridView1.Rows.Count)
                If (Not (DataGridView1.Rows(i).Cells(namecolumn).Value) Is Nothing) Then
                    If (i <> e.RowIndex) AndAlso (DataGridView1.Rows(e.RowIndex).Cells(namecolumn).Value.ToString() = DataGridView1.Rows(i).Cells(namecolumn).Value.ToString()) Then
                        e.Cancel = True
                        MsgBox("This name exist already. please type another.")
                        'return;
                i = (i + 1)
            Loop
    End Sub
    Protected Overrides Function ProcessCmdKey(ByRef msg As Message, ByVal keyData As Keys) As Boolean
        If keyData = Keys.Escape Then
            Dim dgvEditingControl = TryCast(Control.FromHandle(msg.HWnd), DataGridViewTextBoxEditingControl)
            If dgvEditingControl IsNot Nothing Then
                Return True
        Return MyBase.ProcessCmdKey(msg, keyData)
    End Function
End Class
magicdl96
I figured out the solution. Thanks.
JBerns
@magicdl96,
Would you mind sharing your solution? I am sure others could benefit from your experience.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
