Database SAQL CC in Vault
ambrosiPZ23D
ambrosiPZ23D
Dear experts,
I guess no one will answer me. Tabu'
But I still ask you anyway where the data is saved in the DB?
For example, I cannot find the PartNumber even if I scan the entire CC SQL DB.
I need it to set all the PartNumber names in one shot.
Thank you
Frederick_Law
What are you looking for?
Which CC library?
Some part number are generated.  So it'll be equation.
ambrosiPZ23D
I have to make massive changes to the PartNumber.
Most of CC family.
My PartNumber is not calculated
Michael.Navara
Never try to modify CC database directly. If you want to do some modification, use the API functions related to ContentCenter.
ambrosiPZ23D
ok but where can I find the PartNumber in the cc db vault?
even with a query in all the tables of the db I can't find it
ambrosiPZ23D
using VBA (maybe with VB it's better) with a Stored Procedure on SQL to update the PartNumber it takes me 30 minutes, if I could act directly in the SQL tables it would take me 30 seconds
Frederick_Law
Run it overnight?  Or on weekend?
You just need to run it once, right?
Not daily.
I use iLogic to make 100s of drawings.  5 minutes per drawing.  So I just run it overnight.
