Cut Sheet Help
How are most companies handling cut sheets. We had a 3rd party write a program. That would do the following.
What would you recommend in order to accomplish this. Autodesk says manually. Then sent me here.
- Cut sheets.
- Additional sheets of assembly drawing
- 1 per item excluding items on cut list.
- Only items residing in same subfolder of “Design” folder as the assembly drawing file.
- Sheet name = ITEM Item# (e.g., ITEM 2)
- B size sheet
- Cut sheet template title block.
- Prompted entry for the following title block properties.
- Initials of user
- Qty per unit (from Parts List of Assembly drawing)
- Item # (from Parts List of Assembly drawing)
- Ask the user once during the operation; however, prompted entry functionality must still exist so manual overrides can be entered.
- If a cut sheet exists, then do not override the initials if they already exist.
- Sheet Metal - bent
- 3 standard views without hidden lines
- 1 view of flat pattern (Separate sheet if scale is higher than 1:10
- Each view will be scaled based on the formed and flat model extents in the applicable orthographic projection (e.g., front, right, top, etc.) and the customer defined area on the drawing for each view.
- Non-sheet metal or sheet metal unbent.
- 3 standard views with hidden lines
- Bend Annotation on bend lines (standard Inventor function)
- If sheets already exist
- do not overwrite.
- adjust sheet names.
- in case of item number changes
- add additional sheets if necessary.
- new parts added.
- new sheets may have different designer initials.
- remove sheets if necessary.
- existing parts removed.
