CustomTables NameValueMap Informations
FINET_Laurent
Advisor Advisor
FINET_Laurent
Hi folks,
I have a small question about NameValueMaps :
For instance here I want to add a custom table with the API like so : Inventor 2023 Help | CustomTables.Add Method | Autodesk
The last argument is a NameValueMap used to specify more informations. How do I know what properties are aviable for this specific NameValueMap ?
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Andrii_Humeniuk
Hi @FINET_Laurent . Sitting from the description to the argument, it is ignored and does not work.
MoreInfoVariantOptional input NameValueMap that specifies additional information for the table creation. This argument is currently ignored.
This is an optional argument whose default value is null.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
