Custom Ribbon Tabs
Custom Ribbon Tabs
HogueOne
Custom Ribbon Tabs
HogueOne
The Goal: Create a custom ribbon tab in the zero document environment labeled "OP".
The Problem: The tab is being created, but the UI is being reset shortly after - removing the new tab.
The Twist: I've disabled every other addin just to make sure nothing external could be affecting it. I also added diagnostics to check whether the new tab still exists internally, and apparently it does, though I cannot see it. Has anybody else encountered this issue or might be able to offer some insight? Perhaps there's something obvious in the code that I've overlooked.
Imports System.Runtime.InteropServices
Imports Inventor
' This GUID must match the ClassId and ClientId in your .addin file.
' The ComVisible(True) attribute makes this class visible to COM, which is how Inventor finds it.
<GuidAttribute("33B4722C-392E-4E34-9EA3-2E73DD0F1C13"), ComVisible(True)>
Public Class StandardAddInServer
    Implements ApplicationAddInServer
    Private m_inventorApplication As Application
    Private WithEvents m_appEvents As ApplicationEvents
    Private m_uiCreated As Boolean = False
    ' Store references to all created tabs to prevent garbage collection.
    Private m_tabs As New List(Of Inventor.RibbonTab)
    ' Use the user's local app data folder for the log file to avoid permissions issues.
    Private ReadOnly m_logFile As String = System.IO.Path.Combine(
        System.Environment.GetFolderPath(System.Environment.SpecialFolder.LocalApplicationData), "NewTabAddin", "log.txt")
    Private Sub Log(message As String)
        ' This function will write a timestamped message to our log file.
        Try
            Dim logDirectory As String = System.IO.Path.GetDirectoryName(m_logFile)
            If Not System.IO.Directory.Exists(logDirectory) Then
                System.IO.Directory.CreateDirectory(logDirectory)
            Dim logMessage = $"{DateTime.Now:yyyy-MM-dd HH:mm:ss.fff} - {message}{vbCrLf}"
            System.IO.File.AppendAllText(m_logFile, logMessage)
        Catch ex As Exception
            ' If logging fails, we can't do much, but this prevents a crash.
        End Try
    End Sub
    Public Sub Activate(ByVal addInSiteObject As ApplicationAddInSite, ByVal firstTime As Boolean) Implements ApplicationAddInServer.Activate
        Log("--- Add-in Activate Started ---")
        m_inventorApplication = addInSiteObject.Application
        Log("Successfully acquired Inventor Application object.")
        ' Hook into the OnReady event. This event fires once Inventor is fully loaded and idle.
        ' This is the most reliable time to create UI elements.
        m_appEvents = m_inventorApplication.ApplicationEvents
        Log("ApplicationEvents handler set up. Waiting for OnReady event.")
        Log("--- Add-in Activate Finished ---")
    End Sub
    Private Sub AppEvents_OnReady() Handles m_appEvents.OnReady
        Log("--- Inventor OnReady event fired. ---")
        ' The OnReady event can sometimes fire more than once. The flag ensures we only create the UI once.
        If Not m_uiCreated Then
            Log("UI not yet created. Proceeding to create UI.")
            CreateUserInterface()
            m_uiCreated = True
    End Sub
    Private Sub CreateUserInterface()
        Try
            Log("CreateUserInterface method started.")
            Dim uiMan As UserInterfaceManager = m_inventorApplication.UserInterfaceManager
            Log("Successfully acquired UserInterfaceManager.")
            If uiMan.InterfaceStyle = InterfaceStyleEnum.kRibbonInterface Then
                Log("Ribbon interface is active. Proceeding to create tabs.")
                ' Define the list of ribbons where the tab should appear.
                Dim ribbonNames As String() = {"ZeroDoc", "Part", "Assembly", "Drawing"}
                For Each ribbonName In ribbonNames
                    Try
                        Dim ribbon As Ribbon = uiMan.Ribbons.Item(ribbonName)
                        Log($"Successfully acquired '{ribbonName}' ribbon.")
                        ' Use a helper function to create the tab to avoid code duplication.
                        AddTabToRibbon(ribbon)
                        Log($"!!! WARNING: Could not access or modify the '{ribbonName}' ribbon. {ex.Message}")
                    End Try
                Next
            Else
                Log("Ribbon interface is not active. Aborting UI creation.")
            Log("--- UI Creation Finished ---")
            Log($"!!! FATAL ERROR during UI Creation: {ex.ToString()} !!!")
        End Try
    End Sub
    Private Sub AddTabToRibbon(ByVal targetRibbon As Ribbon)
        Try
            ' Check if the tab already exists on this specific ribbon.
            Dim existingTab As Inventor.RibbonTab = Nothing
            Try
                existingTab = targetRibbon.RibbonTabs.Item("id_Tab_OP")
            Catch
                ' Item throws an error if not found, so we catch it and proceed.
            End Try
            If existingTab IsNot Nothing Then
                Log($"Found existing 'OP' tab on ribbon '{targetRibbon.DisplayName}'. No action needed.")
            Else
                Log($"'OP' tab not found on ribbon '{targetRibbon.DisplayName}', attempting to create it now.")
                Dim newTab As Inventor.RibbonTab = targetRibbon.RibbonTabs.Add(
                    DisplayName:="OP",
                    InternalName:="id_Tab_OP",
                    ClientId:="{33B4722C-392E-4E34-9EA3-2E73DD0F1C13}")
                ' IMPORTANT: Add the new tab to our class-level list to keep it alive.
                m_tabs.Add(newTab)
                Log($"Successfully created 'OP' tab on ribbon '{targetRibbon.DisplayName}'.")
            Log($"!!! ERROR adding tab to ribbon '{targetRibbon.DisplayName}': {ex.Message}")
        End Try
    End Sub
    Public Sub Deactivate() Implements ApplicationAddInServer.Deactivate
        Log("--- Add-in Deactivate ---")
        ' Clean up all created tab objects.
        For Each tab As Inventor.RibbonTab In m_tabs
            If tab IsNot Nothing Then
                Try
                    tab.Delete()
                    Marshal.ReleaseComObject(tab)
                    Log($"Error during tab cleanup: {ex.Message}")
                End Try
        Next
        m_tabs.Clear()
        If m_inventorApplication IsNot Nothing Then
            Marshal.ReleaseComObject(m_inventorApplication)
            m_appEvents = Nothing
            m_inventorApplication = Nothing
        GC.Collect()
        GC.WaitForPendingFinalizers()
    End Sub
    Public ReadOnly Property Automation As Object Implements ApplicationAddInServer.Automation
        Get
            Return Nothing
        End Get
    End Property
    Public Sub ExecuteCommand(ByVal commandID As Integer) Implements ApplicationAddInServer.ExecuteCommand
        ' This method is obsolete.
    End Sub
End Class
<?xml version="1.0" encoding="utf-8"?>
<Addin Type="Standard">
	<!-- The Assembly name is the name of your output DLL. -->
	<Assembly>NewTab.dll</Assembly>
	<!-- The ClientId must match the GUID in your StandardAddInServer class. -->
	<ClientId>{33B4722C-392E-4E34-9EA3-2E73DD0F1C13}</ClientId>
	<!-- The ClassId must also match the GUID in your StandardAddInServer class. -->
	<ClassId>{33B4722C-392E-4E34-9EA3-2E73DD0F1C13}</ClassId>
	<DisplayName>New Tab Add-in</DisplayName>
	<Description>A simple add-in that creates a new ribbon tab.</Description>
	<LoadOnStartup>1</LoadOnStartup>
	<UserUnloadable>1</UserUnloadable>
	<Hidden>0</Hidden>
	<SupportedSoftwareVersionGreaterThan>28</SupportedSoftwareVersionGreaterThan>
</Addin>
<Project Sdk="Microsoft.NET.Sdk">
  <PropertyGroup>
    <TargetFramework>net8.0-windows</TargetFramework>
    <ImplicitUsings>enable</ImplicitUsings>
    <Nullable>enable</Nullable>
    <EnableComHosting>true</EnableComHosting>
    <AutoGenerateBindingRedirects>true</AutoGenerateBindingRedirects>
  </PropertyGroup>
  <ItemGroup>
    <COMReference Include="Inventor">
      <WrapperTool>tlbimp</WrapperTool>
      <VersionMinor>0</VersionMinor>
      <VersionMajor>1</VersionMajor>
      <Guid>d98a091d-3a0f-4c3e-b36e-61f62068d488</Guid>
      <Lcid>0</Lcid>
      <Isolated>false</Isolated>
      <EmbedInteropTypes>False</EmbedInteropTypes>
    </COMReference>
  </ItemGroup>
  <ItemGroup>
    <Reference Include="AdWindows">
      <HintPath>C:\Program Files\Autodesk\Inventor 2026\Bin\AdWindows.dll</HintPath>
      <Private>False</Private>
    </Reference>
  </ItemGroup>
  <ItemGroup>
    <None Update="NewTab.addin">
      <CopyToOutputDirectory>PreserveNewest</CopyToOutputDirectory>
    </None>
  </ItemGroup>
  <Target Name="PostBuild" AfterTargets="PostBuildEvent">
    <Exec Command="xcopy /y /d &quot;$(TargetDir)*.*&quot; &quot;%APPDATA%\Autodesk\Inventor 2026\Addins\&quot;" />
  </Target>
</Project>
marcin_otręba
hi, this is happening because you do not have anything on that tab, if it is empty it will be not visible...
try to add panel and some button on it.Before you do keep in mind that internal names must be uniqe for all commands, panels and tabs  so you cant add 4 tabs with the same internal name, also ribbons doesn't have property named Displayname...
here is modified sub:
ps. do you use actual addin template file ?
  Private WithEvents m_buttonDef As ButtonDefinition
            Try
                Try
                    existingTab = targetRibbon.RibbonTabs.Item("id_Tab_OP_" & targetRibbon.InternalName)
                Catch
                End Try
                    Log($"Found existing 'OP' tab on ribbon '{targetRibbon.InternalName}'. No action needed.")
                Else
                    Log($"'OP' tab not found on ribbon '{targetRibbon.InternalName}', attempting to create it now.")
                    Dim newTab As Inventor.RibbonTab = Nothing
                    newTab = targetRibbon.RibbonTabs.Add(
                    DisplayName:="OP",
                    InternalName:="id_Tab_OP_" & targetRibbon.InternalName,
                    ClientId:=AddInClientID)
                    Dim opan As RibbonPanel = newTab.RibbonPanels.Add("OP", "id_Panel_OP_" & targetRibbon.InternalName, AddInClientID)
                    opan.Visible = True
                    newTab.Visible = True
                    Dim controlDefs As ControlDefinitions = m_inventorApplication.CommandManager.ControlDefinitions
                    m_buttonDef = controlDefs.AddButtonDefinition("One", "One_" & targetRibbon.InternalName, CommandTypesEnum.kNonShapeEditCmdType, AddInClientID)
                    opan.CommandControls.AddButton(m_buttonDef)
                    m_tabs.Add(newTab)
                    Log($"Successfully created 'OP' tab on ribbon '{targetRibbon.InternalName}'.")
                Log($"!!! ERROR adding tab to ribbon '{targetRibbon.InternalName}': {ex.Message}")
            End Try
        End Sub
Hi, maybe you want to vote my:
Ideas
or check out my apps:
DrawingTools   View&ColoringTools   MRUFolders   auto-save-replace
HogueOne
I should have replied to myself earlier. I tried adding a panel and a button to my original script because I was suspicious that the core software would remove the new tab if it discovered it empty. I tried almost everything I could think of and it wouldn't work. The last thing I tried was doing a clean uninstall, removing all files, data, registry keys, everything, and reinstalling. After that, I never had an issue. I'm not sure what might have been corrupted about my install. But I had all other addins disabled so it couldn't have been some external influence.
Either way, I appreciate you looking into this. Thank you. Also, I found the template file and I'll be using that as my foundation from now on.
