I have an ilogic rule that lists all my custom properties - but it only lists the propertynames.
How can I get it to also show/add the value of the properties, something like this:
Propertyname = Propertyvalue
Dim oDoc As Document = ThisApplication.ActiveDocument Dim Pros As New ArrayList Dim item As String Dim oPropsets As PropertySets oPropsets = oDoc.PropertySets Dim oPropSet As PropertySet oPropSet = oPropsets.Item("Inventor User Defined Properties") Dim oPro As Inventor.Property For Each oPro In oPropSet Dim Found As Boolean = False For Each item In Pros If oPro.Name = item Then Found = True Next If Found = False Then Pros.Add(oPro.Name) End If Next Dim AllPros As String = "List of all used iProperties:" For Each item In Pros AllPros = AllPros & vbLf & item Next MsgBox(AllPros)
Best regards
TG
Autodesk Inventor/Vault Professional 2021
TG
