Custom Parameter Groups
SpokenEarth
Message 1 of 9
SpokenEarth
Hi forum, I m trying to create custom parameter groups so i can organize my parameters. Here is my syntax code with error so far.
Sub Main()
	Dim oPartDoc As PartDocument = ThisDoc.Document
	Dim oPartCompDef As ComponentDefinition
	oPartCompDef = oPartDoc.ComponentDefinition
    Dim oCustomParamGroup As CustomParameterGroup
    oCustomParamGroup = oPartCompDef.Parameters.CustomParameterGroups.Add("Custom Group", "BS 4825-3")
    oCustomParamGroup.Add("BS 4825-3")
End Sub
Replies (8)
Message 2 of 9
A.Acheson
You will need to add the parameter by object "oUserParam" . The group needs to be deleted if it has been all ready created, in order to add more parameters. I have also added some error catching. Here is a helpful post that shows the API help sample which helped show how it functions. Ensure the user parameters exist before running the rule.
API Help Location
Sub Main()
	Dim oPartCompDef As PartComponentDefinition
	Try
	Catch
	'Delete CustomParameterGroups if one exist in order to add new parameters
	oPartCompDef.Parameters.CustomParameterGroups("BS 4825-3").Delete
	End Try
        ' Create a user parameter
        Dim oUserParam As UserParameter
	Dim oUserParam1 As UserParameter
	Dim oUserParam2 As UserParameter
	Try
	oUserParam = oPartCompDef.Parameters.UserParameters("Hello")
	oUserParam1 = oPartCompDef.Parameters.UserParameters("Hello1")
	oUserParam2 = oPartCompDef.Parameters.UserParameters("Hello2")
	Catch
	End Try
	Try
        oCustomParamGroup.Add(oUserParam)
	oCustomParamGroup.Add(oUserParam1)
	oCustomParamGroup.Add(oUserParam2)
	Catch
	End Try
End Sub
Regards
Alan
Message 3 of 9
SpokenEarth
Hi, the code you provided me does what I was expecting, thought I need to rewrite my parameters but definitely it is worth the time to do so.
I have no API knowledge but I will be very interesting learning.
Thank you so much for your help.
Have a good one.
Message 4 of 9
SpokenEarth
Can this code applied also for text parameters?
Message 5 of 9
A.Acheson
Yes this works with text parameters, I just tested and it works fine.
Regards
Alan
Message 6 of 9
SpokenEarth
Message 7 of 9
SpokenEarth
A.Acheson, earlier today you helped me out with the code for custom parameter groups, the code works fine but when i create two groups the values for the second group appears also in the first group.
Please see attached image at the original post.
Thank you Achilles
Message 8 of 9
A.Acheson
Adding more than 1 group will be just a repeat of the first process. Take note of the number change on the Dim line , this could be any unique name you want. Just ensure you change it anywhere else it appears.
Dim oCustomParamGroup1 As CustomParameterGroup
Dim oCustomParamGroup2 As CustomParameterGroup
I have split up the rule to make it more user friendly and added in grouping drop down with names to make it more readable. You can declare your user names at the start or place them inside the groups before you add them to the group.
Sub Main()
'[User Parameters
	' Declare user parameters
	Try
	Catch
	End Try
'[Group1 Creation
	Try
   	oCustomParamGroup1 = oPartCompDef.Parameters.CustomParameterGroups.Add("Custom Group1","Custom Group1")
	Catch
	oPartCompDef.Parameters.CustomParameterGroups("Custom Group1").Delete
	End Try
	Try
    oCustomParamGroup1.Add(oUserParam)
	oCustomParamGroup1.Add(oUserParam1)
	oCustomParamGroup1.Add(oUserParam2)
	Catch
	End Try
'[Group2 Creation
	Try
   	oCustomParamGroup2 = oPartCompDef.Parameters.CustomParameterGroups.Add("Custom Group2","Custom Group2")
	Catch
	oPartCompDef.Parameters.CustomParameterGroups("Custom Group2").Delete
	oCustomParamGroup2 = oPartCompDef.Parameters.CustomParameterGroups.Add("Custom Group1","Custom Group2")
	End Try
	Try
    oCustomParamGroup2.Add(oUserParam)
	'oCustomParamGroup2.Add(oUserParam1)
	'oCustomParamGroup2.Add(oUserParam2)
	Catch
	End Try
End Sub
Regards
Alan
Message 9 of 9
SpokenEarth
Beautiful!! it works like a charm.
Thank you for the time you took to review my posts Alan and your effort to find a solution
Regards.
Achilles
