Custom iProperty is type Number; needs to write to type string
jwitt1983
jwitt1983
Our new ERP system requires a custom iproperty called "gss_rm_qty" for raw material measurement in string format.
I would like our users to be able to choose whether this value is actual face area or bounding box size (basically length x width)... I've already put together the code to create these custom iproperties (SheetMetalExtentsArea vs SheetMetalActualArea below), however, they are "number" type. Which is preventing me from writing the choice directly to "gss_rm_qty" with the error:
         Overload resolution failed because no Public '=' can be called with these arguments:
         'Public Shared Operator =(a As String, b As String) As Boolean':
         Argument matching parameter 'a' cannot convert from '__ComObject' to 'String'.
Below is the part of the code that is not working...
oMyParameter=ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
	'Setting a userParameter as text parameter
Try
	otester = oMyParameter.Item("ActualOrEstimated")
Catch
	oAreaType = oMyParameter.AddByValue("ActualOrEstimated", "Estimated", UnitsTypeEnum.kTextUnits)
	'make parameter a multivalue list parameter
	MultiValue.SetList("ActualOrEstimated", "Estimated", "Actual")
End Try
If oMyParameter.Item("ActualOrEstimated") = "Estimated" Then
	oCustomProps.Item("gss_rm_qty") = Convert.ToString(oCustomProps.Item("SheetMetalExtentsArea").Value)
Else
	oCustomProps.Item("gss_rm_qty") = Convert.ToString(oCustomProps.Item("SheetMetalActualArea").Value)
End If​
I tried to use CStr() & Convert.ToString()in but it doesn't seem to work either. Maybe I'm not formatting them correctly, idk.
oCustomProps.Item("gss_rm_qty") = CStr(oCustomProps.Item("SheetMetalActualArea").Value)
Any help to get this formatted correctly to output would be appreciated. Thanks!
Ralf_Krieg
Hello
AFAIK, Inventor defines the data type of an iProp by itself. I think your problem is, that you try to assign a property value to another property, not to another propertys value.
Try:
	oCustomProps.Item("gss_rm_qty").value = Convert.ToString(oCustomProps.Item("SheetMetalExtentsArea").Value)
Else
	oCustomProps.Item("gss_rm_qty").value = Convert.ToString(oCustomProps.Item("SheetMetalActualArea").Value)
End If​
R. Krieg
RKW Solutions
www.rkw-solutions.com
jwitt1983
I tried your suggestion of adding .Value to the "gss_rm_qty" property... still same error.
Also tried your suggestion along with using CStr() instead of Convert.ToString()... I believe these are the same but thought it would be worth a shot either way, still same error:
Ralf_Krieg
Hello
Sorry, forgot to say the parameter value is the string you want to compare with "Estimated"
If oMyParameter.Item("ActualOrEstimated").value = "Estimated" Then
R. Krieg
RKW Solutions
Michael.Navara
Your code fragment can't be tested, but try the following modified and commented code
'Define oMyParameter type explicitly for better intellisense
Dim oMyParameter As UserParameters = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
Try
	Dim otester = oMyParameter.Item("ActualOrEstimated")
Catch
End Try
'If oMyParameter.Item("ActualOrEstimated").Value.ToString() = "Estimated" Then
'oCustomProps.Item("gss_rm_qty") = Convert.ToString(oCustomProps.Item("SheetMetalExtentsArea").Value)
'Else
'oCustomProps.Item("gss_rm_qty") = Convert.ToString(oCustomProps.Item("SheetMetalActualArea").Value)
'End If
Dim doubleValue As Double
	doubleValue = oCustomProps.Item("SheetMetalExtentsArea").Value
Else
	doubleValue= oCustomProps.Item("SheetMetalActualArea").Value
'Use string.Format function with possible formatting
'For example {0:N3} => converst value to string rounded to 3 decimal places
oCustomProps.Item("gss_rm_qty").Value = String.Format("{0:N3}", doubleValue)
