Custom iProperties not populating iProperties properly
Message 1 of 12
To whoever can help, I recently created a custom iProperty named 'Finish', for how components are to be... well finished. I did this by creating a text parameter named 'Finish', which is populated by a global iLogic form with a dropdown menu. This dropdown menu is populated using an external rule that both creates the 'Finish' custom iProperty, and then populates the form dropdown for it. The aim is so that in drawings, I pull through the finish custom iProperty to populate a title block for it. This was working brilliant, however now the drawing and the custom tab in iProperties show nothing, but inside the component parameters you can see that the value has populated correctly. I am new to iLogic, and I am not finding the correct solution for this, if anyone could assist, it would be much appreciated.
Replies (11)
Message 2 of 12
WCrihfield
So it sounds like this text parameter and custom iProperty are working OK or as expected in your model documents, but not working in your drawing documents...is that correct?  How is this custom iProperty supposed to populate your drawing's title block?  Is there a textbox within your title block definition's sketch that is linked to this custom iProperty in the model document?  Is this custom iProperty supposed to be copied over to the drawing document, then the textbox in your title block is supposed to be linked to that local custom iProperty?  Is this information somehow being filled in manually within the drawing's title block, like with Prompted Entry or regular text notes?
I may need more information about the specifics of this situation before I can offer a solution for it.
There are settings within the drawing's Document Settings > Drawing tab > Copy Model iProperty Settings..., that can be set-up in your drawing template so that you always copy certain standard iProperties over from a model document when you place its first view.  However, this usually isn't going to be populated with any custom iProperties until after you have placed a model view into the drawing, so it isn't ideal for copying custom iProperties over.  An external iLogic rule and/or a VBA macro with a button in the ribbon are what I would recommend for copying custom iProperties from the model document to the drawing document.  I have a few examples of these types of rules/macros if that's what you think you need.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 12
Hello @WCrihfield ,
The way I have set it up is an external rule that defines finish as a custom iproperty, and then another line that populates the combo box in the iLogic form with selection values. Then I have created a 'User Text Parameter' that links to a title block in the drawing. What you are suggesting with the button for an external iLogic rule is exactly what I want the finished product to look like.
The really odd bit, is that if you are in a part or assembly, and open the parameters menu, the finish property does show up and is filled with the correct value that you select from the form. Almost as if it does not recognize that the User Parameter has a value that equals the custom iProperty.
Everything was working fine, and suddenly, its just stopped working without me changing anything. Ideally, I would like to keep using iLogic for it, for simplicity when I implement throughout the department, I add originally done it as a VBA form, but much prefer how clean iLogic is.
Message 4 of 12
WCrihfield
OK.  So, if you're using an iLogic form, and that form has a drop-down list in it which is already populated with values for you to select from, that list of values is from the user parameter, not the custom iProperty.  And when you select a value from the list in the form and click OK/Done, that sets the value of that user parameter.  Then, if that user parameter is set to be exposed as a custom iProperty, the value of the custom iProperty will be updated when the user parameter's value is changed.  (A parameter is set to be exposed as a custom iProperty when you check the checkbox for that parameter's row in the Parameters dialog box, in the "Export Parameter" column.)  That update action only works in one direction though, as the parameters value is pushed to the custom iProperty when the parameter's value changes, but changing the custom iProperty's value won't update the value of the parameter.  And unlike a multi-value user parameter, an iProperty can only hold one value at a time.
In your post you said that your title block is linked to the user parameter directly, instead of the custom iProperty, correct.  If so, then what is the custom iProperty being used for.  Does that user parameter exist within the drawing document, or just in the model document?  If the user parameter is being copied from the model document to the drawing document, then the title block is linked to that user parameter on the drawing's side, then you may just need to implement a way to keep the drawing side user parameter up to date with the model.  Same for the custom iProperty.  If you are copying the custom iProperty from the model to the drawing, then your title block is linking to the custom iProperty on the drawing side, you may need to implement a way to keep the drawing's custom iProperty up to date with the model.
Here is a link to one of my contribution posts that shows you how to copy custom iProperties from a drawing's model document over to the drawing document by either iLogic rule or VBA macro.
I'm thinking that if your rule is creating the custom iProperty first, then creating and/or populating the user parameter after that, you may want to change that order of actions around, or even eliminate the part that creates the custom iProperty, and just set the parameter to be exposed as a custom iProperty, so it is created automatically (and kept up to date).  If your rule is creating the user parameter, and you don't know how to set it as 'exposed' so it will create the custom user parameter, I can show you how to do that within your rule.
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
If you want and have time, I would appreciate your Vote(s) for My IDEAS 💡or you can Explore My CONTRIBUTIONS
Wesley Crihfield
Message 5 of 12
Hello @WCrihfield , so looking at your solution it makes sense. Seems like all I need to do is forget the custom iProperty, and simply treat this as a Parameter that is pulled through. Think it does need something extra to bring it through to the drawing, as in the parameter window there is no box that would allow me to export that user parameter.
I have now removed the custom iProperty 'code' from the rule, and it only populates the combo box in the form. So the drawing title block is only pulling the 'custom properties - model' ' Finish' parameter. However it is still not displaying, probably from what you are saying with regards to making it exposed, how would I go about doing that?
Message 6 of 12
WCrihfield
Here is an example of how you can set-up the iLogic rule that creates the user parameter and exposes it as a custom iProperty.  When set-up this way, the custom iProperty will be updated every time the user parameter's active value changes, but changing the custom iProperty's value manually won't change or update the active value of the user parameter.
Dim oDocType As DocumentTypeEnum = ThisApplication.ActiveDocumentType
Dim oUParams As UserParameters
If oDocType = DocumentTypeEnum.kPartDocumentObject Or _
	oDocType = DocumentTypeEnum.kAssemblyDocumentObject Then
	oUParams = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
ElseIf oDocType = DocumentTypeEnum.kDrawingDocumentObject Then
	oUParams = ThisDrawing.Document.Parameters.UserParameters
Dim oUParam As UserParameter
Dim oName As String = "FINISH"
Dim oValues As New List(Of String)
oValues.Add("MILL")
oValues.Add("PAINTED")
oValues.Add("GALVANIZED")
oValues.Add("ANNODIZED")
'or
'oValues.AddRange({"MILL","PAINTED","GALVANIZED","ANNODIZED"})
Dim oExists As Boolean ' False by default
For Each oUParam In oUParams
	If oUParam.Name = oName Then
		oUParam.ExpressionList.SetExpressionList(oValues.ToArray)
		oExists = True
Next
If oExists = False Then
	oUParam = oUParams.AddByValue(oName, oValues.Item(1), UnitsTypeEnum.kTextUnits)
	'oUParam.Comment = "SELECT FROM LIST"
	oUParam.IsKey = True
	Try
		'try to expose this parameter as a custom iProperty
		oUParam.ExposedAsProperty = True
		oCPF = oUParam.CustomPropertyFormat
		oCPF.PropertyType = CustomPropertyTypeEnum.kTextPropertyType
		oCPF.Units = ThisApplication.UnitsOfMeasure.GetStringFromType(UnitsTypeEnum.kTextUnits)
	Catch
		MsgBox("Couldn't expose this parameter as a 'custom' iProperty.",,"")
	End Try
'Output Parameters values from this rule to the Model. (Use this before Document Update)
RuleParametersOutput()
'Immediately update the current document.
iLogicVb.DocumentUpdate()
When dealing with text inside a title block sketch of a drawing template file, the options for linking to other stuff is more limited than usual.  In this situation it seems you can't link to any Parameters, and only certain Properties.  The Property options are "Properties - Model", "Properties - Drawing", "Custom Properties - Drawing", "Drawing Properties", "Sheet Properties", "Prompted Entry", "_Piping Style", "Physical Properties - Model", & "Sheet Metal Properties".  The list doesn't include the one we need ("Custom Properties - Model").  That option usually only becomes available in situations like a leader note attached to a model edge in a drawings model view, where it has a clear reference to a model.  So, in light of this situation, I believe the best option left is to use something like the above rule to copy the custom iProperty from the model document to the drawing document, then have your title block text linked to the "Custom Properties - Drawing", and that custom property within the drawing.  This still isn't ideal, because the value of that custom iProperty within the drawing will need to be kept up-to-date somehow.  To keep this value up to date, I'm thinking the best option may be to have an iLogic rule that will copy the model's custom iProperty value to the drawing.  Then put that rule into your Event Triggers dialog (Manage tab > iLogic panel), under the "iProperty Change" event within the model document.  Then every time the iProperties change in the model document, it will trigger the rule to run, which will push the value to the drawing.  (Make sure the rule checks if the drawing document exists before it attempts to push the values to it, to avoid potential errors.)  That rule, or another one like it, could also just be ran manually from the drawing, when you want to be sure it is up-to-date.  I could also help you create that rule too if needed, but it would likely be pretty similar to the one I provided a link to in the earlier post.
Wesley Crihfield
Message 7 of 12
Hello @WCrihfield , for what I am hoping to achieve, does it always have to be exported as a custom iProperty? thought I was overcomplicating it by pulling through as a parameter and custom iProperty.
Message 8 of 12
WCrihfield
I thought so too when I first investigated, because I was just looking at a regular leader drawing note placed on a drawing, and looking at what it had available to be linked to, but that was a different situation than when your dealing with the text within the sketch for a title block definition of a drawing template file.  If you are wanting to set this up within your drawing template file, it won't have a model document to pull custom iProperties from, and can't pull parameters from the model document either, but it can link to custom iProperties within the template document itself and that custom iProperty can already exist within the drawing template file if set-up that way.
And you would still need to keep the multi-value text type user parameter too, because it is being used by your iLogic Form to show you the available options and let you choose one.  Therefore, setting that user parameter within the model file to be 'exposed' as a custom iProperty seems like the next best option.  Then after you place your first model view into a new drawing, the drawing document will then have access to the model, and be able to copy the value of the model's custom iProperty over to itself, which will update the linked text in your title block.  I have similar scenario's set up in some of my drawings too.  I don't specifically have text within my title block linked to 'custom' iProperties, just regular iProperties and other related stuff.  But I do sometimes have custom Sketch Symbols containing text linked to custom iProperties, and other standard drop-in text blocks I use in my drawings that are linked to custom iProperties.  This usually works out OK, but if I'm doing a lot of going back and forth making changes to the model, then back to updating the drawing, I will sometimes have to run either my iLogic rule or the equivalent VBA macro to copy all custom iProperties from the model to the drawing, to make sure those linked texts are up-to-date.  As I said, it's not a 100% ideal scenario, but it is handy and convenient.
Another possible process to accomplish a similar outcome might be to manually run a rule to update your non-linked title block text to show the model's finish after the drawing has been created and drawing views placed onto it.  Of course this wouldn't be ideal either because you would have to remember to run that rule to update that value.  Trying to get a title block text to link to anything that might possibly not exist, especially something in another document, like a custom iProperty or Parameter, is going to involve some level of risk or complication.
A custom add-in might work better for a situation like this.  The add-in can be running/waiting in the background when you start Inventor, for when you place the first drawing view of a model into a drawing document, and when that happens, automatically make all this stuff happen, so you don't have to remember to do anything manually.  Unfortunately, I won't be able to create such an add-in for you, due to corporate restrictions (no employees have admin rights to their own PCs) at work.  But if that is the direction you want to go in, you can either attempt to learn how to make it yourself, or maybe ask others here on the forums to help you create it (if you're even able to install/use them at work).
Wesley Crihfield
Message 9 of 12
Hello @WCrihfield ,
So after a bit of messing around with VBA, I have managed to do it! So I created a userform with a Combo box that has a set of pre-determined values.
From there in the user form code, I assigned oCustomProp1 as a property, and set that item as 'Finish'. Then set the value of 'oCustomProp1' equal to the value of the combo box in the form. Then in the drawing, I have a title block that pulls through the 'Finish' custom properties from the Model. And it works!!!
Might try to copy it over to iLogic when I get a little bit more time, but for now that will work.
Thank you very much for the support!
Message 10 of 12
pbibyFDYXV
Hi Wesley,
I had a similar problem to this thread, which is what brought me here, but my question for you is: do you have any recommendations for books or other resources that I could use to learn the syntax for the language Inventor uses to write macros and anything on applying it to real examples? I have been wanting to improve my company's database for Inventor, so we can get away from using AutoCAD. It is a small company that expects us engineers to solve our own problems and find our own resources internally. So, they would buy us a book or program, but hiring someone to train us is out of the question. I know this is a 4 year old thread, but if you see this and have a moment to give any suggestions, I would greatly appreciate it.
Thank you,
Patrick
Message 11 of 12
WCrihfield
Hi @pbibyFDYXV.  That is a good question.  I am not really aware of a 'book' that is all about automating Inventor by code, but there are several other resources available that can help with that.  About the only books I can think of are ones for learning to use Inventor itself, but I don't know if they go into the automation side of things.  Another of the highly active forum members named Curtis Waguespack helped author some books who's titles start with "Mastering Autodesk Inventor", and he has a link to them on his blog website (https://inventortrenches.blogspot.com/).
I will attach a PDF of some quick reference information I created some time ago, and several Links to other useful resources and references that may be useful.
Likely one of the most basic things to understand are the various primary ways we have available to us for automating Inventor, and what the differences are between them.  Perhaps the oldest is the VBA editor.  When you have Inventor open, you can usually go to the Tools tab, and find a button in the Options panel somewhere that will open this editor, but only if it has been installed.  I believe all newer versions of Inventor since around 2021 have not included the VBA editor in standard installations, due to it being an older coding system that is no longer being maintained by Microsoft, and is therefore a security risk.  But we can still install it later, if we want.  Some who are used to it, and have used if for years, and have lots of resources already prepared in it, find it indispensable, and some others have chosen to shift any existing or new automation solutions/projects over to newer system.  Next is Inventor's iLogic add-in.  Its user interface dialog/window has a far more basic layout/appearance than the VBA editor, so many who have a long history of coding find it a bit lacking in features/tools, but others love its simplicity.  You can read more about that in the PDF, but it lets us use the newer (yet still pretty old) vb.net coding language.  This has a lot of similarities to VBA, but has been much further developed, and has several distinct differences.  The other main tool some folks choose to use is Microsoft's Visual Studio.  It is a huge, highly developed application for all different types of software development in many different coding languages, so it can be very intimidating for those who are not super serious about coding.  It has free versions, and paid versions.  It is completely separate from Inventor, so the resources you create with it often need to be...prepared certain ways to be able to use them either within Inventor, or to control Inventor remotely.  So, if you are just getting started with automating Inventor, and do not have much previous coding experience, I would personally suggest learning all you can about the vb.net coding language, and exploring Inventor's iLogic resources.  One of the key things to understand when using iLogic rules is that the iLogic add-in has some of its own 'object types' and 'methods' that are unique, and not part of the main Inventor API (application programming interface).  The Inventor API is the primary, application level way to interact with Inventor, and the iLogic add-in provides one way to access that resource.  The VBA editor is another way to access Inventor's API.  Visual Studio can also access Inventor's API to control it, but when using VS, you can sometimes use other coding languages, if you are more familiar with them than with vb.net.  Inventor 2024 was using vb.net Framework 4.8 system (slightly older version), while Inventor 2025 is now using vb.net 'Core' 8 (Core term no longer used), which is a newer version with some slight differences.
Wesley Crihfield
Message 12 of 12
pbibyFDYXV
Wow! Thank you for everything. I do have a VBA button that does open the prompt to "How Can I Install VBA?" That shouldn't be too much to get going. I used to have Visual Studio on my personal laptop, and that was the only way I ever truly coded anything, but I'll try VBA before going that route. I appreciate you distinguishing the vb.net for 2024 and 2025; I will see what I can do in 4.8 before I update to INV 2025. I have a lot to sift through thanks to you. I greatly appreciate all that you have shared with this random stranger. Thank you very much!
