Custom Icons on 2010 ribbon menu
I have a couple of macros in the user commands section of my Inventor 2010 ribbon menu.
All the icons are the same. Is there a way to add my own custom icons to each of the different macros?
I used to find that when I hovered over the icon the name of the macro would appear as a tool tip.
This has stopped working, so I have to take a guess as to which icon runs which macro.
Any suggestions greatley appreciated.
Regards
BobT
ACEDeSmedt
If your macro's are in the default project file then:
put a bitmap file in the same folder as your default project.
The name of the file should be like this:
The small image has a size of 16x16, the large a size of 32x32.
Restart inventor to see the change
Use [paint.NET|http://paint.net] to edit your images.
Grtz,
Klaas De Smedt
If this is the solution, push the solution button 😉 (and maybe some kudos)
Autodesk Product Design Suit - Ultimate edition (Subscription)
In my default project I have a module called DespatchModule.
In my application options, the VBA project is G:\3D\inventor code\Default2010.ivb
So I have the following Icon G:\3D\inventor code\DespatchModule.RevUp.Large.bmp
for the macro Public Sub RevUp()
This does not work!
Any thoughts???
Edited by: sanderson81 on Mar 1, 2010 9:58 PM Edited by: sanderson81 on Mar 1, 2010 9:58 PM
Good question. Here's a new blog post to address that.
http://modthemachine.typepad.com/my_weblog/2010/03/buttons-for-vba-macros-in-the-ribbon-user-interface.html
Basically, you need to create a small version of the icon since that's all
that is used by the ribbon for custom commands.
Brian Ekins
Inventor API Product Designer
http://blogs.autodesk.com/modthemachine
ACEDeSmedt
There is only one way to use the large icon but there is a huge drawback.
Using large Icons:
If you look at the Inventor 2010 API Object Model you can notice in the second column under Application.UserInterface a new object called Ribbons
Inventor 2010 API Object Model:
http://images.autodesk.com/adsk/files/inventor2010model.pdf
with these objects you can create and edit ribbons. And there is an option UseLargeIcon
like this :
ThisApplication.UserInterfaceManager.Ribbons("ZeroDoc").RibbonTabs("id_TabTools").RibbonPanels("id_PanelZ_ToolsContentCenter").CommandControls("CCV2BatchPublishButton").UseLargeIcon = True
The Drawback:
Inventor does not save the ribbon bar (except the list of custom commands)
Every time Inventor starts up, you have to manually run a macro (from VBA) to setup your ribbon bar
An advantage for using plug-ins is that they can run on inventor start up, setting up there own ribbon bar
If any one has a solution of the start up problem, please tell me
regards,
Klaas De Smedt
http://www.ace.eu/ Edited by: ACEDeSmedt on Mar 3, 2010 9:15 AM
skyngu
hi, is there any way to wrap text under icon? my sub's name is too long. thanks
Autodesk Inventor Professional 2019
ACEDeSmedt
Not that I know of.
Maybe vbNewLine or \r\n
What you can do is create a kind of shortcut macro with a shorter name that fires the macro you need
