Custom Icons for Macros (R6)
Message 1 of 10
Initially I was able to create serveral icons for existing macros by going
through the routine of:
Tools/Customize/Commands
Select Macros and see all macros that are presently available with associate
icons (.bmp format).
I now have a situation where macros that are loaded and can be seen from the
macro dialog box can't be found in the Tools/Customize/Commands (Select
Macros) dialog box. Some of these macro codes are found in BonusTools
and/or Forms. Does each macro need its own module or need to be referenced
to another location to be available for custom icons? I'm sure I understand
the logic behind this procedure.
Thanks.
Jon Holler
Metro Machine & Engineering Corp.
jholler@metromachine.com
952-259-3615
Replies (9)
Message 2 of 10
Jon, did you ever get it figured out after our email exchange?
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Jon Holler" wrote in message
news:BC8F70F40092FEC7F04905BBE014B567@in.WebX.maYIadrTaRb...
associate
the
referenced
understand
> Thanks.
> Jon Holler
> 952-259-3615
Message 3 of 10
Sean, the micros are still not showing up in the Tools/Custom/Commands/Macro
dialog box. I even deleted the ones I had and they wouldn't come back. I'm
probably missing something very simple.
"Sean Dotson" wrote in message
news:62F39B1835E4F705D44193113ADD28AB@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
going
> associate
> the
> referenced
> understand
> > Thanks.
> > Jon Holler
> > 952-259-3615
Message 4 of 10
Was the Default.ivb made in R5.3? If so many of us have had problems with that. Best to
start with a new default and add your stuff to it.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
news:2D30B2FFE41DB6ACE58BC828172E6905@in.WebX.maYIadrTaRb...
Message 5 of 10
Yep, forgot about that one...
Sean Dotson, PE
"Kent Keller" wrote in message
news:A16289920DC492A5567958ADACA1B93B@in.WebX.maYIadrTaRb...
that. Best to
> Kent
> Assistant Moderator
I'm
Message 6 of 10
Fabulous, I'm not going crazy. Now, I have one more question. How do you
copy the code over to a new project when there are dialog boxes (forms)?
I'm assuming you create a new module (or form) in a new project and - then -
cut and paste. Or do you recreate everything from scratch? Thanks.
that. Best to
> Kent
> Assistant Moderator
I'm
Message 7 of 10
You can drag in drop in the Project Explorer window of the VB editor. Just
have the old and new ones open. Or you can export the form then create a
new one from a file and select the file you exported.
Sean Dotson, PE
news:B109AD6AB73FB7374F05F7AAFA7A61F0@in.WebX.maYIadrTaRb...
then -
with
> that. Best to
> > Kent
> > Assistant Moderator
back.
> I'm
Message 8 of 10
I have seen it fail after cut and paste also. As I remember it was as much a matter of
luck as anything in the end. In the default.ivb right click on the forms and choose
export. Save them to a safe place, then start a new IVB and import them. I cut and
paste the code in the modules, rather than exporting.
It has been quite a while since I had to do it, but I remember even then I had to try
different things until it worked.
Here is from a earlier post from Thilak that might help (also be sure you have a c:\Temp
folder)
> 1. Only macros within the ivb file that is set in the 'Application
options'
> dialog will be displayed.
> 2. The ivb file should NOT contain even a single 'Function'.
> 3. Only 'Sub' routines will be displayed.
> 4. Macro names once displayed in the toolbar customization dialog will
> remain even if you remove/rename it from
> VBA IDE. Thats because it writes it to a vxd file in the temp folder. And
> this file cannot be deleted without restarting
> inventor.
Kent
Assistant Moderator
> that. Best to
> > Kent
> > Assistant Moderator
> I'm
Message 9 of 10
Kent and Sean, thanks for the help. As you say it must be a matter of luck.
I still haven't been able to make it work after trying all of your
suggestions. It's really odd that it worked in the beginning, but just like
that it's gone. Perhaps Autodesk needs to do some further development.
news:43490129DC18B19D68F6ADACEEA81046@in.WebX.maYIadrTaRb...
much a matter of
and choose
I cut and
had to try
have a c:\Temp
> folder)
> options'
And
> > inventor.
> Kent
> Assistant Moderator
you
then -
with
> > that. Best to
> > > Kent
> > > Assistant Moderator
back.
> > I'm
Message 10 of 10
Maybe I hade the same type of problem. (Macros didn't show up in
Customize/Commands/Macros)
This is how I did:
Open the VBA file (Ctrl + F11) and place the cursor in the module.
Activate/switch to Inventor and "type" Ctrl + F8.
Then create a new macro.
Now you hopefully can find your "old" macros also.
Lars
"Jon Holler" skrev i meddelandet
news:B941EC9A08DE68040ED77FE8C74B2220@in.WebX.maYIadrTaRb...
luck.
like
> much a matter of
forms
> and choose
them.
> I cut and
I
> had to try
you
> have a c:\Temp
> > folder)
> > options'
> And
> > > inventor.
> > Kent
> > Assistant Moderator
> you
(forms)?
> then -
problems
> with
> > > that. Best to
> > > > Kent
> > > > Assistant Moderator
> back.
> > > I'm
