custom button command
id like to know if it is possible to create a custom button with existing command  in inventor.
thanks
inventor 2011
vault 2012
xiaodong_liang
Autodesk Support
Autodesk Support
You can create your own buttons, please refer to the topic in API help document:
Ribbon User Interface Customization using the API >> ButtonDefinition
to know how a button works.
Then, in when the button is executed (clicked), you can call existing command by its internal name. .e.g.
  ThisApplication.ControlDefinitions("AppMeasureMomentCmd").Execute
this will execute the Measure Moment command.
To get the commands you want to run, the following VBA code could be helpful. It dumps all existing commands.
Sub dumpCommands()
Dim oC As ControlDefinition
Open "c:\command.txt" For Output As #1
For Each oC In ThisApplication.CommandManager.ControlDefinitions
  Write #1, "[Display Name]: "; oC.DisplayName & "  [Inner Name]: " & oC.InternalName
Next
Close #1
End Sub
