Message 1 of 1
Custom BOM export
My iLogic code works just how I want it to when there is only 1 sheet. When there are multiple sheets I get this error
"SaveAs method of Workbook class failed". My code can call the sheet by it's number or by calling the first sheet, which is where the BOM is. Tried the code both ways same result. I'm hoping there's a simple fix, I've spent way to much time on this as is. Here's my code:
'-------------Start Of ilogic ------------------------------------------------ 'get the path and name of the drawing file path_and_name = ThisDoc.PathAndFileName(False) ' without extension THEWAY=ThisDoc.Path 'for the filename formating 'define oDoc oDoc = ThisDoc.Document 'specify the drawing sheet oSheet = oDoc.Sheets("Sheet:1") ' sheet by name 'oSheet = oDoc.Sheets(1) ' first sheet ' say there is a Partslist on the sheet. oPartslist = oSheet.PartsLists(1) ' create a new NameValueMap object oOptions = ThisApplication.TransientObjects.CreateNameValueMap 'specify an existing template file to use For formatting colors, fonts, etc oOptions.Value("Template") = "C:\Users\dschaefe\Desktop\PROJECT-TB\BOM TEMPLATES\CLOROX BOM 2020.xlsx" 'specify the columns to export oOptions.Value("ExportedColumns") = "ITEM QTY;PART NUMBER;DESCRIPTION;VENDOR" 'specify the start cell oOptions.Value("StartingCell") = "B18" 'specify the XLS tab name 'here the file name is used oOptions.Value("TableName") = "CLOROX BOM" 'choose to include the parts list title row oOptions.Value("IncludeTitle") = False 'choose to autofit the column width in the xls file oOptions.Value("AutoFitColumnWidth") = False 'export the Partslist to Excel with options oPartslist.Export(THEWAY & "\" & iProperties.Value("Project", "Part Number") & "R" & iProperties.Value("Project", "Revision Number") & "_" & iProperties.Value("Project", "Description") & ".xlsx", PartsListFileFormatEnum.kMicrosoftExcel, oOptions) '-------------End of ilogic ------------------------------------------------
