Creating section views on drawing by ilogic rule
malmal02122023
malmal02122023
I would like to create sections view A-A to H-H for frame by Ilogic rule as shown below. Could you help me please?
There are sections with offset 10 mm from elements (L-rofiles 20x20x3) and section depth 40 mm.
The section views with broken align and rotated to horizontal line.
Thanks for the advice and Best regards
BM_Ashraf
You can adjust this code to fit your needs
Sub Main()
 	'check
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
	'Current Drawing Document
Dim oDrawDoc As DrawingDocument = ThisDoc.Document
'Active sheet
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
'Drawing View
Dim oFirst_view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Please select the main view")
If oFirst_view Is Nothing Then Exit Sub
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
	'Adding a drawing sketch to the view
Dim oDrawingSketch As DrawingSketch = oFirst_view.Sketches.Add
    oDrawingSketch.Edit
	'View height
    Dim oFWHeight As Double  = oFirst_view.Height+2
    'Points for secion line
	Dim oPoints(1) As Point2d
    oPoints(0) = oTG.CreatePoint2d(0, oFWHeight)
    oPoints(1) = oTG.CreatePoint2d(0, -oFWHeight)
    'Sketch line(vertical)
    Dim oSketchLine As SketchLine = oDrawingSketch.SketchLines.AddByTwoPoints(oPoints(0), oPoints(1))
    Call oDrawingSketch.GeometricConstraints.AddVertical(oSketchLine)
    oDrawingSketch.ExitEdit
Dim oInsertionPoint As Point2d	= oTG.CreatePoint2d((oFirst_view.Position.X+oFirst_view.Width+1),(oFirst_view.Position.Y))
Dim oSectionView As SectionDrawingView
oSectionView = oSheet.DrawingViews.AddSectionView(oFirst_view, oDrawingSketch, oInsertionPoint, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
oSectionView.ReverseDirection
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
malmal02122023
Thank you very much. It works. I still have a question. How to give a name for view sections from work plane names in model (By creating view section along work plane 1, 2 itp. and naming them as work plane name?
BM_Ashraf
This one should do the job.
Sub Main()
 	'check
'Active sheet
'Drawing View
Dim oFirst_view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Please select the main view, ESC to Cancel")
    oDrawingSketch.Edit
	'View height
'Getting the section name from Work Plane
'Referenced Document
Dim oRDoc As Document = oFirst_view.ReferencedDocumentDescriptor.ReferencedDocument
ThisApplication.Documents.Open(oRDoc.FullDocumentName, True)
'Getting the WorkPlane Name
Dim oWP As WorkPlane = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kWorkPlaneFilter, "Please select the Work Plane, ESC to Cancel")
If Not oWP Is Nothing Then oSectionView.Name = oWP.Name
oDrawDoc.Activate
End Sub
Blue Mech
malmal02122023
Thank you again.
malmal02122023
There is one more question.
In this code, a section is created through a sketch placed in the center of the main view. Is it possible to place a sketch on the selected working plane by previously selecting working plane?
Thanks again.
