Creating Leader by VB
NachoShaw
Advisor Advisor
NachoShaw
Hi
Anyone know how to create a leader in VB or VBA? i can create a leader to a pre selected item on the drawing sheet but i need to make it behave like the native Inventor whereas, you click 2 points and press enter to enter text. i need that but in VB 🙂
Thanks in advance for any replies
Nigel
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
Hi
yes i had already found those blogs. unfortunately, they assume that the leader that lesader points are already predetermined. i need to allow the user the create a leader in the standard way (i.e pick the first point then pick the second with the leader attached to the mouse pointer as the inventor built in version) and when the use has finished clicking points (usually 2 points), enter the text "REFRENCE ONLY" programatically.
i can add a leader with by clicking one location and a leader appears
i can add a leader by clicking 2 points (no leader attached to the mouse pointer)
Nigel
Nacho
rjay75
In order to select the points you want for leader creation you have to use intereaction events.
ie = appInventor.CommandManager.CreateInteractionEvents();
se = ie.SelectEvents;
ie.StatusBarText = "Select Edge";
ie.SetCursor(CursorTypeEnum.kCursorBuiltInCrosshair);
ie.OnTerminate += new InteractionEventsSink_OnTerminateEventHandler(ie_OnTerminate);
se.OnSelect += new SelectEventsSink_OnSelectEventHandler(se_OnSelect);
se.AddSelectionFilter(SelectionFilterEnum.kDrawingCurveSegmentFilter);
se.SingleSelectEnabled = true;
 Responding to the OnSelect gives you the curve and the point.
To get the next points use the mouse events.
ig = ie.InteractionGraphics;
ie.MouseEvents.MouseMoveEnabled = true;
me = ie.MouseEvents;
me.OnMouseClick += new MouseEventsSink_OnMouseClickEventHandler(me_OnMouseClick);
The OnMouseClick will give you subsequent points.
NachoShaw
Hi
thanks for the reply. I will try this later but i do assume i will not see the visual element of adding a leader i.e click the first point and the leader being attached to the mouse pointer until i click the second point.
without seeing the the leader mid process, its hard to see where the leader will be placed per se.
Nacho
rjay75
No you won't be able to see the 'rubberband' between points. To do that respond to the OnMouseMove event and in it modify the OverlayClientGraphics on the InteractionGraphics object to draw a line between the first point and last point. Look up ClientGraphics in the API help and look in the Advanced section in these DeveCamp classes.
It's not straight forward but ok when you can wrap your head around it.
