Creating Joint on the center of a slot
dg2405
dg2405
Can somebody tell me how to define the GeometryIntent to place something to the middle of a slot? Creating joints via iLogic on any intent on the face works well, but i need the middle of the slot:
Looking with vba on a manually created joint on a slot, the values "point" and "intent" are different. The point-coordinates are the end of the slot, and the intent-coordinates are the middle. But i don't know how to achieve this!
dg2405
Anybody has a hint how to do this? I have tried everything.... This thing makes me cracy 🙂
^_^clovis^_^
Hi dg2405,
I suppose a "join" constraint is a 3d constraint in one go. So you might have to define a surface contact + point on this surface + an orientation. Seeing the type of screw you're using, I'd use the top of it for the surface contact , the center of it as point contact and the 2 centers of the hole as orientation.
My 2 cents
dg2405
I think it's not possible to create a joint on a slot with api!
Even copying a jointdefinition from a joint which is created manually on the middle of a slot fails:
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim oJoint As AssemblyJoint = oAsmCompDef.Joints("Starr:1")
Dim oJointDef As AssemblyJointDefinition = oJoint.Definition.Copy()
oAsmCompDef.Joints.Add(oJointDef)
 The new joint is created on the center of one of the two slot arcs.
@Anonymous Please tell me if it's possible to this with api and when yes tell me how.
^_^clovis^_^
If a "joint" constraint can't be created, you could add a workpoint en axis in the feature "create slot" where you want to constraint a screw. Also, you could create some iMates with those point en axis.
^_^clovis^_^
maybe..
The part receiving the screw:
create slot
share the sketch
create a cylinder as extra solid in its center.
put an iMate on it Insert "center-axis down".
make the extra cylinder invisible
the screw:
add an iMate insert on top "center-axis down"
Inventor UI needs surface as ref.
