Creating custom message for each hole type in sheet metal drawing.
Hi All
I have a question regarding rules or some automation regarding the hole and thread function in the drawing environment. I have some sheet metal parts to send to fabricators. The sheet metal parts have clearance holes to install self clinch nuts and studs. I want to tell the fabricator if a particular hole is a clearance hole for a screw, clearance hole to install clinch nut or a clearance hole to install a threaded stud.
I am following Pemnet fasteners and studs and following their standards to assign specific hole sizes according to the choice of clinch nuts and studs. For example M4 clinch nut needs 5.41mm clearance hole, M5 clinch nut needs 6.35mm clearance hole etc. I want to have a functionality where when I use hole and thread option to indicate the hole size on the drawing it should also diplay have some custom message of what that hole is going to be used for based on the hole size.
For example : 5.41 mm thru hole on sheet should indicate something like " Hole for M4 clinch nut" or 6.35 mm thru hole should say "Hole for M5 clinch nut". If I could add a function of displaying Total quantity for each hole type will be an added bonus.
Is there anyway I can achieve this. Or some other way in which I will be able to mention clearly in the drawing what each hole size stands for. This will save me a lot of time. I have lots of parts and mentioning each hole manually is just a hard work , not a smart work and I can make mistakes.
Any help will be much appreciated.
Thanks in advance
Manjinder
